4age into ke70 tacho signal
Postby Mike- » Wed Dec 19, 2007 6:28 pm
ok ive got a 4age in my ke70 wagon which ive put dash with tacho into
where does the tacho get its signal from? the coil?
and if someone knows the colour wire from the dash that would be helpful too
thanks for the input
Mike-
Postby l1ttle_d3vil » Wed Dec 19, 2007 6:34 pm
connect the wire from the back of your tacho onto the negative terminal of the coil.
take the gauges/console out and it will probably be a black wire, you should be able to follow the "trails" on the back of the gauges from the terminal where the wire connects to where the actual gauge is on the dash. probably doesn't make much sense but pull it off and you'll see what i mean :wink:
Postby Mike- » Wed Dec 19, 2007 7:19 pm
sorted
Mike-
