Car started fine this morning then go to start in the arvo and only clicking not even trying to turn over. This happened about a month ago and then next day the car began starting fine up until now. batt is still reading 12-13 volts, so im guessing its the starter motor. I can still roll start it but not sure how long this will last.
its a ae101 4age silvertop.... can someone point out where the starter motor is so i can give a big dirty wack as i cant find where it is. cheers
Problem solved - was my old battery. thanks for the help
