Mounting a fire extinguisher into a SW20
Postby touge rolla » Wed Dec 26, 2007 6:24 pm
My mum got me a fire extinguisher for Christmas as per my request.
Now I am left with where and how to mount it.
This is my first choice, though i'm not sure it will be easy due to there only being solid metal on the bottom half of it
here would be easy to reach and install but my leg hits it whilst on the foot rest (not too big a problem though)
and here it may restrict seat forward movement, but would be out of my way the rest of the time
any other location suggestions/feedback?
also are there any requirements as to how it is mounted? ie what sort of bolts/screw are used? and what it can/cannot be secured to? where have other SW20 owners with a fire extinguisher mounted theirs?
touge rolla
Postby Mr Revhead » Wed Dec 26, 2007 6:36 pm
i would go for the last option.
have a good look and see if it will fit. it probably will.
failing that, how about some where behind the seat?
there are rules for mounting if you want to do track days or motorsport stuff
Postby Boosted_162 » Wed Dec 26, 2007 6:36 pm
I havent mounted one in my SW20, but ill be putting mine in front of the seat, with the bracket attaching to the mounting holes of the seats. Someone on here came up with the idea.
Postby fangsport » Wed Dec 26, 2007 6:49 pm
Boosted_162 wrote:I havent mounted one in my SW20, but ill be putting mine in front of the seat, with the bracket attaching to the mounting holes of the seats. Someone on here came up with the idea.
and what a bloody good idea it was!! saves drilling holes in the car.
fangsport
Postby touge rolla » Wed Dec 26, 2007 6:53 pm
Yes I really want to take it onto the track, think in just front of the seat is the winner. But don't know the MSNZ rules for how it must be fixed. I imagine bolted/screwed but Is there anything more specific? rules on MSNZ website are .pdf so can't read it :(
touge rolla
Postby fangsport » Wed Dec 26, 2007 6:56 pm
6mm bolts. in a position that can be reached from a seated position.
fangsport
Postby Santa'sBoostinSleigh » Thu Dec 27, 2007 12:23 am
the way we set a few up for the MM07 trackday was attaching the extinguisher to a piece of steel, which was then bent/welded, then drilled so that it bolted to the seat mounts.
i would do a MS Paint, but i am lazy tonight
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Leon » Thu Dec 27, 2007 6:44 am
Also: big panel washers under floor, and either nylock, or double bolt.
Postby Adamal » Thu Dec 27, 2007 9:13 am
What about removing the center console piece on the firewall and mounting it there? Easily accessable to driver and co-driver.
Postby pureadrenalin » Thu Dec 27, 2007 9:50 am
How often do you have midgets driving your car to restrict seat movement?
I have mine mounted in front of my seat like option three (but my seats don't move).
Either of the other two places you would be kicking it all the time, brusing knee's and ankles, getting your overalls caught on it. So I don't know if it would pass scrutneering.
pureadrenalin
Postby xsspeed » Thu Dec 27, 2007 6:03 pm
have seen some mounted in front of passenger seat, tho i dont know if thats in line with the rules
Postby touge rolla » Thu Dec 27, 2007 6:16 pm
Adamal wrote:What about removing the center console piece on the firewall and mounting it there? Easily accessable to driver and co-driver.
I know that's where i was going to put it, but decided that what little storage space there is in a mr2 is valuable.
touge rolla
Postby Alex B » Thu Dec 27, 2007 7:08 pm
Might want to watch the fuel tank with option 2.
Postby no_8wire » Fri Dec 28, 2007 10:20 am
Thats how mine is mounted in my AW11
no_8wire
Postby postfach » Fri Dec 28, 2007 10:32 am
Leon wrote:Also: big panel washers under floor, and either nylock, or double bolt.
So a couple of 6mm bolts with decent washers on the other side, and nylock/fujilok nuts will be sweet?
postfach
Postby Bling » Fri Dec 28, 2007 10:50 am
Extinguishers shall be installed in accordance with the following:
(a) A retaining system incorporating quick release metal fastenings/straps, or material of equivalent strength (ie Kevlar), secured to the structure of the vehicle by a minimum of two 6mm bolts with panel washers and locknuts.
(b) Hand held extinguishers shall be positioned within easy reach of the occupant/s while normally seated.
Postby touge rolla » Fri Dec 28, 2007 8:05 pm
^ah thank you that's what i needed to know :)
touge rolla
Postby Bling » Fri Dec 28, 2007 9:26 pm
thats from here:
viewtopic.php?t=50855
8)
Postby touge rolla » Sat Dec 29, 2007 9:23 pm
ah typical i searched in the tech and members projects sections only :roll:
touge rolla
Postby AJz » Sat Dec 29, 2007 10:13 pm
im with the infront/under your seat.
Think about it this way, your more than likely the only one to drive it right, how often are you going to move that seat ???
just my 2c
I had vtax :(
AJz
