mr2 aw11 headlights!
Postby jonno* » Sun Dec 30, 2007 9:11 pm
Hey guys, just picked up a nice red '89 aw11 today, it's going great apart from one thing. My headlights won't go down on their own - i have to do it manually twisting those little knobs, which gets old pretty fast. I've tried turning the headlights off before I turn the car off, but they still won't go down :/ I'm doing it right according to the manual, so does anybody know any tricks to get these to work?
thanks
jonno*
Postby levinguy » Sun Dec 30, 2007 9:13 pm
the headlight retractor relay has gone by the sound of it
its in the frunk, on your right if your looking into it, little black box, try spraying a bit of crc on the contacts
levinguy
Postby jonno* » Sun Dec 30, 2007 9:31 pm
oh cheers dude, did you mean the fuse box though? there's a little gizmo underneath the reservoir for the windscreen wiper fluid which is also on the right and hooked into the cables coming from the headlights, but the manual talks about the fuse box, and the fuse looks a bit messed up :s
also, pretty noob question haha, but is crc the same as wd40? think the olds took the only can of crc when they went away on the boat, i have this other stuff though, will it do the trick?
jonno*
Postby levinguy » Sun Dec 30, 2007 9:54 pm
not the fuse box, its the little black box in the top right hand corner, to the right of the window washer pump thing
levinguy
Postby Mr Revhead » Sun Dec 30, 2007 10:19 pm
do they go up ok?
the relay maynot be black... iirc mine was orange...
its similar in size/shape to a pack i ciggies i think.
and is clearly marked. on the passenger side of the frunk on the firewall
Postby jonno* » Sun Dec 30, 2007 10:19 pm
Ah yeah, see what you mean, didn't seem to do the trick though :( I'll take another look at the fuses tomorrow though, see which ones do what, because the one i did take out looked pretty buggered.
edit - revhead - they go up sweet as, just not down, could there be a different thing controlling upwards motors compared to downward? :s
jonno*
Postby Mr Revhead » Sun Dec 30, 2007 10:29 pm
have a good look at the plugs/wiring
i remember that when working on the lights the manual says to remove that relay and they will not come down on your hands!
Postby levinguy » Sun Dec 30, 2007 10:34 pm
where abouts are you? i have a spare relay you can buy if you want?
levinguy
Postby jonno* » Sun Dec 30, 2007 10:38 pm
Mr Revhead wrote:have a good look at the plugs/wiring
Haha yeah, mine has two lines of exclamation marks and a massive 'danger' sign where it says that.
Levinguy, I'm in pakuranga, how much would you want for it? Shouldn't be a difference between different years/jap import vs nz new right?
jonno*
Postby mr_monkey » Mon Dec 31, 2007 12:39 pm
I wonder if anyone has ever lost their fingers to popup lights. that'd be hilariousness.
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby barryogen » Mon Dec 31, 2007 3:03 pm
mr_monkey wrote:I wonder if anyone has ever lost their fingers to popup lights. that'd be hilariousness.
yeah, in a "haha you're fuxord for life now" kinda way...
you have an odd sense of humour... I like it.
barryogen
2ZZ Guru in training
Postby mr_monkey » Mon Dec 31, 2007 3:57 pm
are you hitting on me? :lol: :lol:
-Nathan
mr_monkey
Postby barryogen » Mon Dec 31, 2007 4:16 pm
mr_monkey wrote:
barryogen wrote:you have an odd sense of humour... I like it.
err, no... not even I'm that sick. although my wife may argue that.
barryogen
Postby Wanabee Kiwi » Wed Jan 02, 2008 4:36 pm
talking of MR2 headlights are there any non pop-up options available for the AW11?
[admin edit: oversized sig image removed - read the rules]
Wanabee Kiwi
Postby Lloyd » Wed Jan 02, 2008 4:41 pm
Yeah, Jonno has some :lol:
Postby mr_monkey » Wed Jan 02, 2008 4:44 pm
Wanabee Kiwi wrote:talking of MR2 headlights are there any non pop-up options available for the AW11?
Its pretty much up to you to make your own :-D
Sounds like fun to me 8) 8)
-Nathan
mr_monkey
Postby jonno* » Sat Jan 05, 2008 5:17 pm
heh, just to clear it up in the end. picked up a new retractor relay, but that didn't seem to solve the problem, so i dug round a little deeper and found a fuse called 'RTR' which was busted, which probably stands for 'retractor relay' or some such i guess, so it oughta work when i replace that.
anybody need an aw11 retractor relay then :P you can have it back if your old one doesn't show up rob!
jonno*
