silvertop into aw11 - won't start!! - fault code 12
Postby levinguy » Tue Jan 01, 2008 11:13 am
hey
have just put a silvertop into an aw11 and it starts but it won't rev at all,
anything more then a small amount of throttle will just stall the engine, what have i done wrong?
tried searching but that brang up nothing
levinguy
Postby Alex B » Tue Jan 01, 2008 11:38 am
Got any fault codes?
Postby Leon » Tue Jan 01, 2008 6:00 pm
Starting, idling, and then dying when throttle is applied can be a bunch of things. Do you have a spare ignitor unit you can swap onto it? My old Corolla GT did that when the ignitor went bung.
Postby levinguy » Tue Jan 01, 2008 7:51 pm
never thought of fault codes.. too hung over from the night before,
it brang up 14 - which is ignition i think
will try another igniter, earth is good.
thanks for the help so far
levinguy
Postby levinguy » Wed Jan 02, 2008 7:21 pm
ok now it won't start at all.. no codes now either
levinguy
Postby levinguy » Wed Jan 02, 2008 7:28 pm
has fuel coming out the return
has spark
no codes are coming up
any ideas why it wont start? coil/igniter earthed straight to battery
levinguy
Postby Lloyd » Wed Jan 02, 2008 8:54 pm
Has it got decent spark or just a weak looking spark? What are the plugs looking like?
Postby levinguy » Wed Jan 02, 2008 8:59 pm
spark looks decent - but i could be wrong
fault code of 12 comes up now
brand new leads and plugs
levinguy
Postby levinguy » Wed Jan 02, 2008 9:02 pm
pulled a plug out, a bit of oil, not to much, black with a bit of white on the end
levinguy
Postby 85AW20v » Wed Jan 02, 2008 11:16 pm
Check that there is an earth in place from the AFM - I think it's white with a black trace. Also, when you hold the AFM flap open with the key on, the fuel pump should run - if it doesn't you've got a wiring problem with the circuit open relay and fuel pump.
See ya
Simon
85 MR2 20v
85AW20v
Postby levinguy » Wed Jan 02, 2008 11:21 pm
got the fuel pump wired straight to 12v with the key on, had a circuit open relay hooked up, but i wanted to erase that from the equation, will hook it back up when the cars going though!
levinguy
Postby postfach » Wed Jan 02, 2008 11:35 pm
According to the site I just found, code 12 is RPM or Knock Sensor.
postfach
Postby levinguy » Wed Jan 02, 2008 11:48 pm
12 RPM Signal
Diagnosis
* No "NE" or "G" signal to ECU within 2 seconds after engine has been cranked.
Trouble Area
* Distributor, or CPS, circuit
* Distributor or CPS
* Starter signal circuit
* ECU
so should i just run new wires from the dizzy to the ecu?
i mean i could have damaged some wires taking the loom in and out, i did this after it first started, just trying to think what could have changed
levinguy
Postby sergei » Thu Jan 03, 2008 2:25 am
Have hooked up earth terminal next to the thermostat housing?
Postby levinguy » Thu Jan 03, 2008 2:46 am
yeah, well what was on there before, its two wires coming from the engine loom that ground there, sound right?
levinguy
Postby flygt4 » Thu Jan 03, 2008 9:33 am
when i had issues with my dizzy i was able to check the continuity of the wires back to the ecu , and look for the small voltage to see if it was triggering correctly.
flygt4
Postby levinguy » Thu Jan 03, 2008 11:56 am
might sound stupid, but how do i go about doing that?
levinguy
Postby levinguy » Thu Jan 03, 2008 12:05 pm
now it only brings up the code 21, after clearing the codes again which is oxy sensor, no biggie, would just run richer without.
im really frustrated and confused now!
levinguy
Postby levinguy » Thu Jan 03, 2008 5:32 pm
pulled the loom, dodgey injector 12v. will re-do it and hopefully will be going!, feel so stupid now that i found it :oops: but oh well
thanks for all the help, really appreciated
levinguy
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
