Anyone got any names / recommendations? or people to avoid?
-Matt
Simon85MR220v wrote:Is Morrinsville too far away? if not ring Udy Automotive. Doesn't have a dyno but knows his stuff and tunes by going up and down the road. Knows plenty enough to put in a basic map and tune it from there.
l1ttle_d3vil wrote:reason I would prefer dyno is because they are alot more reliable and give a safer tune, correct? i want it to be a reliable car which I can drive all the time if needed.
Simon85MR220v wrote:Ivan Udy has done my brothers rally car twice for Targa, one motor without and one with turbo and we didn't have any tuning related problems.
He also got an AE86 running better than another tuner in Hamilton who does have a dyno and had the car for a day to see why it felt flat. As soon as Ivan looked at the numbers after he'd hooked it all up he knew something wasn't right. Turned out the vacuum line to the Link had come off and the dyno tuner couldn't find what the problem was. It was Ivan's experience that found the problem and that is the sort of tuner you're wanting to find and use.
IH8TEC wrote:any decent tuner with a dyno will do a road tune after to check it anyway.
"Yeah the dyno is saferand more importantly, allows you to properly tune your ignition which is fairly critical for reliability. You can definitely get a driveable fuel map from road tuning (private roads only etc) but the final 10% and the ignition map really require a dyno.
Users browsing this forum: No registered users and 33 guests
