Caldina Front Mount I/C
Postby bbq1988 » Thu Jan 03, 2008 9:44 am
Hey guys, who has put a frontmount into their car?
I am intersted in doing it but am wanting alittle info first :)
Cheers for the help!
Baked, Not Fried.
bbq1988
Postby flygt4 » Thu Jan 03, 2008 10:33 am
first step is to have a look in the bumper space and see what you may clash with. some cars keep aircon and powersteering and oil coolers up in there so it may be neccessary to move it around a bit.
on gtfours its common to rotate the compressor housing to a more sensible position,(it points up standard) unsure whether this is done for caldinas, or even possible.
keep the cooler size reasonable,dont go too big, and use decent T bolt clamps and joiners. boost leaks kill turbos quite quickly.
you'd probly need custom piping, i havent heard of kits for these although with their increasing popularity some may be available now.
flygt4
Postby barryogen » Thu Jan 03, 2008 11:04 am
a friend of mine has done it on his caldina, had to do it all custom.
He used a very wide, short and thin(700x150x65) IC as it suited the room under the bumper better, just got it from trademe.
The lag on it was only just noticeable, but intake temps went down considerably, enough that he took it in for a re-tune to get a/f ratios checked, it was leaning out a bit, nothing scary, and still safe enough according to what he said.
Seems to go quite hard now(when compared to stock)
barryogen
2ZZ Guru in training
Postby bbq1988 » Thu Jan 03, 2008 12:40 pm
im likeing the idea just for the cooled charge, should do the engine alittle good aswell
Baked, Not Fried.
bbq1988
Postby WCKWGN » Thu Jan 03, 2008 1:06 pm
Driven performance now has a manifold for the caldina if you want to change your turbo as well. As Flygt4 said inverting the turbo is the way to do it easier and take out a couple of bends in the piping in doing so as well but only applicable on a aftermarket hair dryer setup.
here are some pics of how mine is setup which maybe handy
WCKWGN
Postby Skin » Thu Jan 03, 2008 1:31 pm
Buy my ST205 Water to air setup!!!
:D
Edit - buy my turbo as well!!
Will do both for $900 :wink:
cogent wrote:iPhones can eat a dick.
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby bbq1988 » Thu Jan 03, 2008 1:52 pm
Skin wrote:Buy my ST205 Water to air setup!!!
:D
Cheers, but no thanks :)
Baked, Not Fried.
bbq1988
Postby Adydas » Thu Jan 03, 2008 1:54 pm
People just dont understand the awsumness of wta, if i bought a caldina id So put a st20 wta on it just to be awsum
Adydas
Postby Skin » Thu Jan 03, 2008 2:18 pm
Adydas wrote:People just dont understand the awsumness of wta, if i bought a caldina id So put a st20 wta on it just to be awsum
Exactly. Heaps easier to install, more efficent, and cost effective.
I'm really suprised that both my WTA setup and my ct20b havent gone yet to be honest...
1981 Mazda RX7
1997 Toyota Corolla
Skin
Postby Santa'sBoostinSleigh » Sun Jan 06, 2008 11:04 pm
i looked into doing this ages ago and decided against if after homework
too much hassle, too much chopping into things, and was going to get very pricey to do it properly
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby gleem » Mon Jan 07, 2008 12:27 pm
how much did you get yours qoute for santa?
gleem
Postby Santa'sBoostinSleigh » Mon Jan 07, 2008 1:02 pm
i was going to do most of the work myself and or get cashies done
but even then it still came out too much work to make it worthwhile doing
part of the problem is that i definitely want A/C and didnt want to chop the crap out of my bumper and the engine bay
plus i also didnt want to get rid of my spotlights
bear in mind that you cant (easily) use a el cheapo tardme special I/C, you really need one that is better sized to fit
also you will probably have to mount the battery elseware
rotating the turbo is a damn good idea to reduce bends
i was going to run 2" and 2.5" piping to reduce lag
most I/C's seem to come with stupidly large 3" in/oulets
i was going to run mine similar to teh Ex-Driven Performance Caldina (TWSTD's) and have the pipe going thru the guard where the fuse box sits
but i found i was still going to have to use more bends than ideal, and that i had to chop far too many holes for it to plumb up
modifying cars, especially caldinas isnt cheap
Santa's Mega Sale
Postby WCKWGN » Mon Jan 07, 2008 3:14 pm
i will try find my invoice from the turbo shop tonight for my build cost and copy it on up..... but yeah not cheap any way.
i will have to say the expense doesnt outway the fun i have had in it since!!
WCKWGN
Postby bluemaumau » Mon Jan 07, 2008 3:33 pm
why dont people want st205 wta?
Postby Mr.Phreak » Mon Jan 07, 2008 4:04 pm
bluemaumau wrote:why dont people want st205 wta?
Since most people buy A2A coolers that are way too big for their use but fills up the gaping hole they carved out of their front bumper, I'm guessing it just doesn't look cool enough for them
Mr.Phreak
Postby Crampy » Mon Jan 07, 2008 4:29 pm
I think one of those water to air barrel intercoolers would look mint in a Caldina engine bay. Do it and be different.
Crampy
Postby bbq1988 » Mon Jan 07, 2008 4:31 pm
i want to keep my a/c ect as santa said, i would also like to stay away from cutting large holes, im starting to sway towards water to air, whats the pro's and cons
Baked, Not Fried.
bbq1988
Postby Crampy » Mon Jan 07, 2008 4:35 pm
Water to air is heavier, but you can get shorter intake piping.
You'll need all the other associated parts as well, like pump, water reservior and a heat exchanger for the water up front.
Water to air is able to lower intake temps lower than an air to air setup, as water is generally colder than the ambient air.
Crampy
Postby barryogen » Mon Jan 07, 2008 4:44 pm
Crampy wrote:Water to air is able to lower intake temps lower than an air to air setup, as water is generally colder than the ambient air.
and if cruising(as in 100km/h in top gear), it tends to get below ambient due to being off boost and wind chill factor... so, if you're cruising, and then decide to boot it, it's even more fun :)
*edit*
incidentally, I've bought his(skins) w2a setup :)
barryogen
Postby Skin » Mon Jan 07, 2008 4:54 pm
Ha, and cheap as hell as well!!
Dont know if i told you, but its got a brand new heat exchanger as well!!
1981 Mazda RX7
1997 Toyota Corolla
Skin
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
