Where to get Custom crankshaft pulley 4age-harmonic balance
Postby Bazda » Sun Jan 13, 2008 9:42 pm
Im trying to find out where I can get a 4age crankshaft pulley in alloy with a harmonic balancer.
I see there are alot of companies that make them for V8s, but I cant seem to find any japanese ones.
Does anyone know who can custom make these or know where to buy them for a 4age?
thanks
Postby Rick » Sun Jan 13, 2008 10:36 pm
I would get in contact with Tony he sells alot of pulleys on trademe, if he cant make or get one in for you I am sure he will know someone that can.
five_elements12345@hotmail.com
http://www.trademe.co.nz/Members/Listings.aspx?member=144796
Postby l1ttle_d3vil » Mon Jan 14, 2008 8:02 am
just bought a set of that guy, they look ...... immaculate :lol:
he makes gilmours for a 4age too :?
Postby bluemaumau » Mon Jan 14, 2008 11:56 am
how muchies?
Postby Bling » Mon Jan 14, 2008 11:59 am
click the above link :wink:
Postby Mr Revhead » Mon Jan 14, 2008 12:41 pm
those are solid alloy pulleys... not what bazda is after
Postby Paulio » Mon Jan 14, 2008 12:51 pm
i got a harmonic balancer from precision parts in aussie (through repco) but its not alloy. think it was around the 300 mark.
Paulio
Postby Dell'Orto » Mon Jan 14, 2008 5:24 pm
Can Precision Engineering make one up for you?
Postby Bazda » Mon Jan 14, 2008 5:31 pm
Dell'Orto wrote:Can Precision Engineering make one up for you?
not one with harmonic balancer
Postby bluemaumau » Mon Jan 14, 2008 6:14 pm
BZG|Bling wrote:click the above link :wink:
i knew that, was testing you all 8)
Postby bluemaumau » Mon Jan 14, 2008 9:37 pm
what are the pros and cons of not/having a harmonic balncer?
something to do with dampening vibrations i take it
Postby Bazda » Mon Jan 14, 2008 9:59 pm
bluemaumau wrote:what are the pros and cons of not/having a harmonic balncer?
wear ur crank/bearings out faster
could induce a crank somewhere in the crank later on breaking the crank
better to have one rather not to have one :).
Postby Mr Revhead » Mon Jan 14, 2008 10:12 pm
why not get the whole assembly balanced?
Postby Bazda » Mon Jan 14, 2008 10:28 pm
Mr Revhead wrote:why not get the whole assembly balanced?
my whole assembly is balanced, thats not the point, its the harmonics the engine produces that your trying to dampen.
For a 10s car you have to be using a pulley with a harmonic balancer, its in the rule book :D
Postby gmacrae » Tue Jan 15, 2008 2:30 pm
i got the front of the stock pulley turned off on my silvertop (p/s a/c) which doesnt touch any of the rubber insulating the rear half of the pulley - worth doing if you dont want p/s or a/c. As well as the pulley ring itself, a good portion of the cast meat came off with it so definitely shaved some weight.
gmacrae
Postby Bazda » Tue Jan 15, 2008 5:39 pm
gmacrae wrote:i got the front of the stock pulley turned off on my silvertop (p/s a/c) which doesnt touch any of the rubber insulating the rear half of the pulley - worth doing if you dont want p/s or a/c. As well as the pulley ring itself, a good portion of the cast meat came off with it so definitely shaved some weight.
I like my PS so thats not an option
Postby Paulio » Wed Jan 16, 2008 3:40 pm
perhaps evil_Si?
Paulio
