Dell'Orto wrote:Can Precision Engineering make one up for you?
BZG|Bling wrote:click the above link
bluemaumau wrote:what are the pros and cons of not/having a harmonic balncer?
something to do with dampening vibrations i take it
Mr Revhead wrote:why not get the whole assembly balanced?
gmacrae wrote:i got the front of the stock pulley turned off on my silvertop (p/s a/c) which doesnt touch any of the rubber insulating the rear half of the pulley - worth doing if you dont want p/s or a/c. As well as the pulley ring itself, a good portion of the cast meat came off with it so definitely shaved some weight.
