HELP!! 4agte runing issuse
Postby escortman » Tue Jan 15, 2008 8:26 pm
4agze ecu and fueling with walbro pump
when i plug in the tps its idles fine when its warm but as soon as it comes up to temp it starts surging and almost dies when u give it some trottle, when i unplug tps it idles fine, i tried to set the tps but cudnt get it less that about 12kilo ohms has anybody done this beofre that could give some pointers?
4x4 toyota blizzard offroader
escortman
Postby escortman » Wed Jan 16, 2008 6:45 pm
sum1 plez?
escortman
Postby rollaholic » Wed Jan 16, 2008 7:09 pm
isint there something in the FAQs about setting TPS's?
Postby escortman » Wed Jan 16, 2008 9:34 pm
yeh i did wat it said but cudnt get it lower than 12 k ohms
escortman
Postby Crampy » Wed Jan 16, 2008 10:02 pm
What throttle body and what TPS are you using? If it's a 4AGE throttle body and 4AGZE TPS, it might be different anlge on the arm that controls it.
Just a guess, might need to confirm.
Crampy
Postby escortman » Wed Jan 16, 2008 10:09 pm
o hmm i cnt actually member if i took it off the ze or not im using 4age throttle body
escortman
Postby Pelo » Thu Jan 17, 2008 12:08 am
If you are using a gze ecu you will need a gze tps. To fit the gze tps to the na throttle body you need to swap the armatures that rotate the tps as well.
It might be going backwards if you didn't do this.
* I now remember the main reason I swapped them around is because the plugs were different, so the na tps would probably work anyway.
Easiest way to set the tps is with the whole throttle body off the car.
Pelo
Postby escortman » Thu Jan 17, 2008 6:47 am
o ic damn any1 have a ze tps i cant member if it was still on the ze throttle body or not
escortman
Postby Crampy » Thu Jan 17, 2008 10:37 am
I'll have a look see around all of my spare bits for one Matt.
Not promising anything though.
Crampy
Postby Bazda » Thu Jan 17, 2008 11:36 pm
i've never used a gze tps on the n/a throttle body when going to turbo, i just used the tps that originally fits to the n/a throttle body and its always been fine.
Postby Caveman » Thu Jan 17, 2008 11:41 pm
Do you have the tps wired correctly? Sounds like you may be grounding the vcc (sometimes just called vc) wire on accident.
Likewise with bazda 4agze ecu should take na tps fine, speaking from my old car.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby escortman » Fri Jan 18, 2008 9:08 am
Caveman wrote:Do you have the tps wired correctly? Sounds like you may be grounding the vcc (sometimes just called vc) wire on accident.
um i cant see y it would be earthing out, as it ran fine when it was ze and i havnt changed anything
escortman
could the sensor have fuked out ?
escortman
Postby escortman » Sat Jan 19, 2008 10:38 am
does any1 have a tb with sensor on that i could try on my car to see if that changes it?
escortman
Postby Crampy » Sun Jan 20, 2008 11:48 am
escortman wrote:does any1 have a tb with sensor on that i could try on my car to see if that changes it?
Yes. I've got a Smallport throttle, Redtop Bigport throttle and a good ol' Bluey throttle, all complete with TPS and in running motors.
I did have a 4AGZE throttle with TPS as well, but I'd have to have a hunt to see if I've still got it.
Which one do you want to try?
The Bluetop one is on my Daily runner, so would be a wee bit of a pain. The other two are not going anywhere in a hurry.
Gimme a text if you want to come and grab it.
027 291 0955.
Crampy
Postby Crampy » Sun Jan 20, 2008 11:59 am
Turns out I've still got your number. So.........
Text sent.
Crampy
Postby IH8TEC » Sun Jan 20, 2008 4:07 pm
i never changed the little arm thing on the t/b, but i just used the tps which is for that particular ecu and no probs, so i just used my gze tps when i was using std computer (4agze)
now i went to link i changed to the 4age tps because they are more readily available if it stuffs out
Postby bluemaumau » Sun Jan 20, 2008 6:49 pm
ive got a 4agze t/b with tps if you want.pm me
