New thread
Postby rollaholic » Fri Jan 25, 2008 10:29 pm
i recommend finding a replacement steering column before you try any tapping, drilling, dieing antics.
good way to find yourself carless when things go pear shaped ;)
Postby FST4RD » Fri Jan 25, 2008 10:33 pm
Only thing is that if you ever worked on a starion anyone will tell you that it's the last job you want to do to one of them is remove the steering colum.... Totally serious....
This is why i'm trying to find out other options before having to resort to fing a colum and then attempting to swap them...
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby rollaholic » Fri Jan 25, 2008 10:36 pm
im not saying go ahead and swap it - i know you have a starion, i figured spare parts would be sparse. might want to find where you can get one from before you start hacking into your current one ;)
Postby FST4RD » Fri Jan 25, 2008 10:38 pm
rollaholic wrote:im not saying go ahead and swap it - i know you have a starion, i figured spare parts would be sparse. might want to find where you can get one from before you start hacking into your current one ;)
Yeah thats true I see what you mean :)
Well suppose I should find one.... then try a new thread on the one thats in there, if that doesn't work try drilling and tapping, then if that doesn't work pull half the front of the car to bits and try to get the old colum out and new one in :x
FST4RD
Postby rollaholic » Fri Jan 25, 2008 10:42 pm
i once accidentally scored the end of a camshaft at work, the scratch was big enough to damage the seal when the camshaft was turning - so it leaked and leaked.
solution was to send camshaft to engine rebuilder, they built up a layer of weld of some sort over the end of the camshaft, then machined it back down to the correct size to get rid of the imperfection.
maybe you could find a place to do something similar for you, only with a thread instead?
Postby FST4RD » Sat Jan 26, 2008 7:54 am
rollaholic wrote:i once accidentally scored the end of a camshaft at work, the scratch was big enough to damage the seal when the camshaft was turning - so it leaked and leaked.
I think if the other solutions couldn't work and I had to take it I would do that or get it lathed down to the next size and threaded properly.
I mean the nut does up tight enough that if you yank on the steering wheel real hard it doesn't pull off but it's a little bit loose and you can feel the lack of thread...
FST4RD
Postby Matty104 » Sat Jan 26, 2008 9:20 am
id suggest to just run the m12 die over the old thread and see if you can regain any meat (as cross threading it in the past may have not nesesarily taken to much steel away just squashed it if that makes sense) once you run the die over, run some thread tape around the thread , (or locktite if your never going to take it off) and it should be more secure , and if you feel you want more safety do the m8 or m6 bolt down the center if the shaft with the washers
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby FST4RD » Sat Jan 26, 2008 1:18 pm
Matty104 wrote:id suggest to just run the m12 die over the old thread and see if you can regain any meat (as cross threading it in the past may have not nesesarily taken to much steel away just squashed it if that makes sense) once you run the die over, run some thread tape around the thread , (or locktite if your never going to take it off) and it should be more secure , and if you feel you want more safety do the m8 or m6 bolt down the center if the shaft with the washers
Thanks for that, thats the plan for now...
Just got to find someone with a big enough die to run over it...
FST4RD
Postby Dell'Orto » Sat Jan 26, 2008 1:40 pm
You can actually get a die that is in 2 pieces, which you clamp around the good thread and wind back up over the stuffed section, which could be enough to give you a good threaded section again.
Postby FST4RD » Sat Jan 26, 2008 3:20 pm
Dell'Orto wrote:You can actually get a die that is in 2 pieces, which you clamp around the good thread and wind back up over the stuffed section, which could be enough to give you a good threaded section again.
Really? might head down to Mitre 10 mega and have a nosey I think...
FST4RD
Postby RS13 » Sat Jan 26, 2008 3:46 pm
They're called die nuts. I'm pretty sure split dies are for resizing threads, whereas die nuts are for cleaning up threads, which is probably what you want to try first before resizing. You get them in tap and die kits, not sure where you'd go to get one by itself.. perhaps an engineering tool store if Mitre10 can't help you.
RS13
Postby Dell'Orto » Sat Jan 26, 2008 7:39 pm
Yeah I'd say they're more of an engineering type tool than your average Mitre 10 item, but you never know.
