good way to find yourself carless when things go pear shaped
rollaholic wrote:im not saying go ahead and swap it - i know you have a starion, i figured spare parts would be sparse. might want to find where you can get one from before you start hacking into your current one
rollaholic wrote:i once accidentally scored the end of a camshaft at work, the scratch was big enough to damage the seal when the camshaft was turning - so it leaked and leaked.
solution was to send camshaft to engine rebuilder, they built up a layer of weld of some sort over the end of the camshaft, then machined it back down to the correct size to get rid of the imperfection.
maybe you could find a place to do something similar for you, only with a thread instead?
Matty104 wrote:id suggest to just run the m12 die over the old thread and see if you can regain any meat (as cross threading it in the past may have not nesesarily taken to much steel away just squashed it if that makes sense) once you run the die over, run some thread tape around the thread , (or locktite if your never going to take it off) and it should be more secure , and if you feel you want more safety do the m8 or m6 bolt down the center if the shaft with the washers
Dell'Orto wrote:You can actually get a die that is in 2 pieces, which you clamp around the good thread and wind back up over the stuffed section, which could be enough to give you a good threaded section again.
FST4RD wrote:Dell'Orto wrote:You can actually get a die that is in 2 pieces, which you clamp around the good thread and wind back up over the stuffed section, which could be enough to give you a good threaded section again.
Really? might head down to Mitre 10 mega and have a nosey I think...
