sway bar noise
sway bar noise
Postby barryogen » Wed Feb 06, 2008 2:50 pm
I have a TRD sway bar fitted to my little RunX, and it makes a clunking noise on lateral movement... is this normal?
I know it is the sway bar as removing it the noise disappears.
It may not matter too much to me as I'm selling it, but the potential new owner will want to know what was causing it, hence my post.
barryogen
2ZZ Guru in training
Postby Mr Revhead » Wed Feb 06, 2008 3:17 pm
only way for it to be the sway bar is if its loose
or maybe its not the bar
maybe the extra stiffness in the bar is causing movement in the rear beam bushs
Postby barryogen » Wed Feb 06, 2008 3:20 pm
heh, the 45 odd mins it took me to struggle to get it undone says that it certainly isn't/wasn't loose... I might just drop it off at a suspension place as I suspect that it will be tricky to diagnose online :lol:
barryogen
Postby AceSniper » Wed Feb 06, 2008 3:29 pm
I would be looking at the bushes... even if they do look alright they can be noisey.
after that check your swaybar links for any play
AceSniper
Postby Mr Revhead » Wed Feb 06, 2008 3:32 pm
zze corollas dont have bushes or links
rear suspension is totally different from all previous FWD corollas
Postby Mr Revhead » Wed Feb 06, 2008 3:38 pm
http://www.theautochannel.com/news/2002/05/08/140092.3-lg.jpg
the rear beam flexes, the sway bar bolts into the beam to stiffen it
the bar is solid mounted to the beam
Postby Lloyd » Wed Feb 06, 2008 6:29 pm
I stand by my sarcastic comment, "New cars are awesome" :)
Postby barryogen » Wed Feb 06, 2008 8:42 pm
I must say driving without the sway bar makes it interesting...
the only thing majorly different is if i change direction twice in quick succession the back end swings like it's a wagon, but never seems to let go, well, I'm not driving it hard either.
barryogen
Postby matt dunn » Wed Feb 06, 2008 9:10 pm
Front bar I take it?
When we got our BZT wagon is had a noise very similar,
after an extensive search it turned out that the two bolts where it bolted to the firewall in the centre of the strut bar, were tight, but not tight enough and under cornering it would move the 2mm or so in the hole through the bar and make a loud clunk on each direction change.
Maybe you have a similar issue?
Postby Mr Revhead » Wed Feb 06, 2008 10:24 pm
his issue is in the rear
:o
Postby barryogen » Tue Feb 12, 2008 10:17 am
had a decent look at it last night.
the bushes at the very front of the rear arm flex/crush as they should, but when the bar is added, it flexes more, and hence the noise.
Will find out from rev head about cost of nolathane replacements... but I tend to think that it would make it rather jarring.
barryogen
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
