silicon reducers and heatwrap
Postby gleem » Thu Feb 07, 2008 10:25 pm
need some 3 to 2.5, anyone know where to get them for cheap, they are around 30bux for one on trademe which seems awfuly expensive for what they are also where is a good place to get some cheap heatwrap from, whats a good price to pay for this
cheers!
gleem
Postby flygt4 » Thu Feb 07, 2008 10:28 pm
30$ is dead cheap.
you can spend up to 75$ each for name brand reducers if you're not careful. over 100$ for elbows. stop being a jew :wink:
flygt4
Postby doin donuts » Thu Feb 07, 2008 10:31 pm
hey mate, if you wanting heat wrap, its pretty expensive but if yo want you can buy mine off me, i got it when i thought i was going to turb my ae85 but going NA now, so if you want pm me :)
4agze ae86 trueno...let the fun begin!!
doin donuts
Postby flygt4 » Thu Feb 07, 2008 10:33 pm
depending on the application you might not want to cheap out on joiners either. I had poor joiners originally, it cost me the price of a new turbo due to a boost leak and subsequent failure.
i figured it much cheaper to opt for brand name joiners and t bolts clamps in the future.
flygt4
Postby l1ttle_d3vil » Thu Feb 07, 2008 10:41 pm
flygt4 wrote:depending on the application you might not want to cheap out on joiners either. I had poor joiners originally, it cost me the price of a new turbo due to a boost leak and subsequent failure.
why were the joiners "cheap"? ie - how did they fail?
interested in this as I have no idea what type of joiners i'm running at the moment (some are radiator hose :wink: ) and standard clips, works fine for 7psi but think i'll need to upgrade for 18psi :x
im pretty sure i've got a 2.5" - 3" joiner here which I have left over from my setup, don't need it. any donations towards getting my car on the road in exchange for said joiner are greatfully accepted :lol:
Postby Bling » Thu Feb 07, 2008 11:04 pm
l1ttle_d3vil wrote:im pretty sure i've got a 2.5" - 3" joiner here.....
radiator hose? :wink:
Postby fx gt » Thu Feb 07, 2008 11:07 pm
radiator hose? :wink:[/quote/]
them some big hose :lol:
fx gt
Postby escortman » Fri Feb 08, 2008 7:04 am
hahaha i rolled radiator hose for a while 2
4x4 toyota blizzard offroader
escortman
Postby flygt4 » Fri Feb 08, 2008 7:38 am
not sure what they were, they were black multi-ply joiners, one looked like a piece of standard joiner from a stock evo setup or something.
they werent flexible enough, one split and while i was lapping round manfield.i noticed the boost was low at ~7psi instead of 14psi, did another half lap and then pitted. was too late by then, had overspun the turbo and the bearings were gone.
could hear a pinging noise at idle that turned out to be the compressor clipping the side of the housing and then siezing, and then freeing itself again.
flygt4
Postby l1ttle_d3vil » Fri Feb 08, 2008 8:16 am
not too reliable if its from a factory setup - would've thought they'd be good. the 2.5" - 3" i've got is a proper silicon joiner, just not sure what brand thats all.
and my black radiator hose blends in with the piping anyway for extra coolness 8)
Postby escortman » Fri Feb 08, 2008 7:09 pm
flygt4 wrote:not sure what they were, they were black multi-ply joiners, one looked like a piece of standard joiner from a stock evo setup or something.
o and did u have the wastegate feed at like the intake manifold or something?
escortman
Postby flygt4 » Fri Feb 08, 2008 8:22 pm
not sure what you're asking there.
everything was plumbed in as it should be, only things taken off inlet manifold are boost gauge and reference pressure for the boost controller, which as far as i am aware is standard practice. (i believe its more important to be measuring and adjusting the actual air entering the engine rather than that at the turbo, which could be 1-2psi different from the pressure going into the engine.)
i reckon if i had been running 2x boost gauges, one from the turbo and one from the inlet manifold i would have seen the pressure drop immediately, ie 29psi at turbo and 7psi at engine,losing 22psi through a split joiner for example.
definately something i would consider useful in hindsight.
flygt4
Postby escortman » Fri Feb 08, 2008 9:39 pm
i mean lik how the boost controller will only be reading 7 at engine but cuz of this wont open wastegate so lik u did kills the turbo, i have my boost gauge at inlet manifold but wategate feed between turbo and intercooler so i dont have that problem
escortman
Postby flygt4 » Fri Feb 08, 2008 11:06 pm
yeh i see what you're saying.
my wastegate gets its pressure from the turbo, but that is bled by the controller which gets its reference from the intake manifold.
with my boost controller turned off, it will function as you say,but once i set it to increase pressure it will raise or lower based on what the engine is seeing.
flygt4
Postby escortman » Sat Feb 09, 2008 9:43 am
ook yep ic
escortman
Postby tsoob » Sun Feb 10, 2008 12:09 pm
i have joiners at the shop ill pm you with a price on monday.
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby gleem » Sun Feb 10, 2008 7:39 pm
great thanks nick
gleem
Postby IH8TEC » Sun Feb 10, 2008 7:50 pm
to be honest, there isnt' much difference at all between the cheap blue ones on trademe and the "brand name"
hell they probably come from the same place, just someone wants to put a different name on them. and mark up the crap out of them
Postby postfach » Sun Feb 10, 2008 8:05 pm
FWIW, I've been using no name trademe joiners for over a year now with no problems whatsoever. I think the biggest issues with splitting/tearing them is with pipes that don't line up well, heat, and excessive engine movement.
postfach
Postby gleem » Sun Feb 10, 2008 8:11 pm
cheers, im not too fussed just after the cheapest i can find, alex you wouldnt know where i can get the oil feed bit that goes on to the turbo?
gleem
