Quick check re: smallport 4age injectors/ecu
Postby ~SlideWays~ » Thu Feb 14, 2008 8:57 am
My brother just bought an ae82 FXGT in excellent condition, it has a Smallport conversion and looks to have swapped the loom correctly.
Just to confirm.
- Does the redtop ecu have the three grey plugs?
- Are redtop/smallport injectors green?
- How to tell if correct distributor is used?
~SlideWays~
Postby xsspeed » Thu Feb 14, 2008 9:24 am
send me a pic bro and ill have a look at mine, mine also has a smallport in ae82 fxgt, but im a bit dubious about whether its just smallport rocker covers atm!! bought it cheap as chips for parts so not too worried
Postby ~SlideWays~ » Thu Feb 14, 2008 9:29 am
xsspeed wrote:send me a pic bro and ill have a look at mine, mine also has a smallport in ae82 fxgt, but im a bit dubious about whether its just smallport rocker covers atm!! bought it cheap as chips for parts so not too worried
No pics as of yet, got back at 1am this morning from picking it up....5hrs sleep and posting on TS at work FTW! :lol:
*off to get a coffee* lol
If you are worried about it being the cam covers. First thing to look out for is the intake manifold, a real "redtop" is a smallport so NO tvis.
~SlideWays~
Postby Paulio » Thu Feb 14, 2008 9:42 am
yes and yes. not sure about the major differences of the dizzy between bluetop and redtop though, my redtop uses the small metal plugs into the dizzy (about 3mm), thats possibly the only diff.
Paulio
Postby ~SlideWays~ » Thu Feb 14, 2008 9:54 am
not_paul_from_waiheke wrote:yes and yes. not sure about the major differences of the dizzy between bluetop and redtop though, my redtop uses the small metal plugs into the dizzy (about 3mm), thats possibly the only diff.
Cheers for confirming the first 2. The distributor is definitely different on the smallport but I'm not sure if there is any visual difference externally.
*mmmm stupidly strong coffeeee* :P
~SlideWays~
Postby xsspeed » Thu Feb 14, 2008 11:59 am
ok yeah sorry forgot to add definately non tvis,
sounds the same as me, up to sweet FA at work need something to stay awake, TS!
Postby bluemaumau » Thu Feb 14, 2008 1:15 pm
i just sold some smallport injectors, they were green
Postby Stu- » Thu Feb 14, 2008 1:41 pm
Doesn't the Bluetop dizzy work on a points style setup while the redtop one has the multi tooth wheel etc?
Project Thread
Stu-
Postby Trls250s » Thu Feb 14, 2008 1:50 pm
Real good way to tell is the oil drain on the back of the head. Bigport doesnt have this where smallport does.
And the lack of TVIS is a good pointer as even trying to remove it to fool someone you still need to fit an adapter plate (so there will be this large alumnium shiny plate where tvis should live.)
Everything else is just nit picking, the only power maker is the head (and ecu).
Its hard to tell by the colours of stuff because stuff changes through the generations. IE bigport loom out of a ae86 is completely different to one out of a AW11 mr2 in terms of colour but all the pins and everything it does is the same.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby pc » Thu Feb 14, 2008 2:11 pm
Easiest thing to spot is 4 runners in the inlet manifold instead of the 8 in a TVIS model... but he didn't ask that :lol:
yes - 3 grey plugs on ECU, bluetop is yellow
yes - injectors are brightish (not dark) green, bluetop injectors are grey
the dizzys look different, but the plug on the smallport dizzy is grey, where on a bluetop it is yellow
Can I have a look at it sometime? I need to figure how to do the same on my car.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby ~SlideWays~ » Thu Feb 14, 2008 2:31 pm
pc wrote:Can I have a look at it sometime? I need to figure how to do the same on my car.
Yep Im sure he'd be sweet with that.
~SlideWays~
meh
Postby ezy10s » Thu Feb 14, 2008 2:46 pm
small port engine/ecu setup just wont work with a big port distributor so if it runs ok then its definately a smallport distributor.
Member #244
Gone fishing until further notice
ezy10s
Re: meh
Postby ~SlideWays~ » Thu Feb 14, 2008 2:48 pm
ezy10s wrote:small port engine/ecu setup just wont work with a big port distributor so if it runs ok then its definately a smallport distributor.
Awesome thanks for confirming that.
~SlideWays~
