Please help with installing pod filter
Postby Jooce » Thu Feb 14, 2008 7:10 pm
hey so ive bought this pod filter and pipe from drivenperformance.. heres a pic
and ive removed the factory air filter, heres a pic of that. (bear with me)
Jooce
Postby 78ke30 » Thu Feb 14, 2008 7:12 pm
What is the engine? Does it have a AFM, if so you need to keep this. do you have a pic of what you have removed?
Previously owned: 1980 1275 gt mini clubman, 1979 mini clubman, 1980 ford escort, 1978 toyota corolla ke30
Current AE111 levin BZR
78ke30
Postby Jooce » Thu Feb 14, 2008 7:16 pm
okay so ive got this far lol,
a few things i need to know is,
do i need to plug the little hose that comes from the engine intake thingy into the little pipe thats sticking out of the intake pipe i bought? ive tried it without putting it in and it makes a rather loud sucking sound and the engine idles quite high..
Also that plug that goes into the rubber bung. i think its the air flow sensor? does that have to be plugged in? because i have to stretch it underneath the pipe to get it to fit.
One more thing, when i put the whole thing on by just sliding the blue joiner over the engine intake thingy its quite loose and i can easily slide it off? yet i only got two of the screw tightner thingys (lol) to connect the pod filter to the pipe and the blue connector to the pipe! If anyone can understand what the hell im talking about and give me a few pointers it would be much appreciated..
Jooce
Postby Jooce » Thu Feb 14, 2008 7:22 pm
sorry,
its 16 valve redtop smallport. ive been told its MAP something if that helps.. heres a pic of everything ive removed.
Jooce
Postby d1 mule » Thu Feb 14, 2008 7:31 pm
MAP= Manifold Absoloute Pressure, it takes a pressure reading from the inlet manifold, there will b a hose going to a little black box somewhere (donno where on ae92).
at a guess id say bung the holes up on the stainless pipe and throw a screw into the pipes that you have removed and it well go sweet as
d1 mule
Postby Jooce » Thu Feb 14, 2008 7:33 pm
okay heres a pic of when i just rammed the blue connector onto the engine thingy..
okay im assuming this is roughly how its spose to be done? am i spose to use another clamp to hold the blue connector onto the engine thingy? WTF IS IT ACTUALLY CALLED?
Jooce
Postby Jooce » Thu Feb 14, 2008 7:34 pm
and i know the clamp is spose to be on the groove on the blue connector. but theres nothing else holding it on.. i can just easily slip the whole pipe off! 8O
Jooce
Postby Jooce » Thu Feb 14, 2008 7:37 pm
i really urgently need to get this done becoz i gota drive it to work tomorrow hahahaha and its getting dark soon :roll:
Jooce
Postby Grrrrrrr! » Thu Feb 14, 2008 7:38 pm
I haven't looked at a smallport for a while but i think there is a sensor in the airbox (intake air temp sensor). carefully remove this from the airbox and hopefully it fits that mounting boss on the intake tube.
Also you really want to find a way to get cold air into the pod filter, sucking hot air off the engine will lose you power.
Grrrrrrr!
Postby Jooce » Thu Feb 14, 2008 7:44 pm
yeh that plug that kinda looks like a spear head? it goes into the rubber bung on the intake tube but its a bit of a stretch to get it there, wot i need to to know is..
1, do i just block up the small hose thats coming off the engine thingy thats making a massive sucking noise when the engines running. OR is that what plugs into the little pipe thats sticking out of the intake tube?
2, how do i put the whole bloody thing on the engine thingy so its secure? do i have to sacrifice a screw clamp thing so its nice and tight?
Jooce
Postby touge rolla » Thu Feb 14, 2008 7:50 pm
Jooce wrote:1, do i just block up the ... is that what plugs into the little pipe thats sticking out of the intake tube?
yes
Jooce wrote:2, how do i put the whole bloody thing on the engine thingy so its secure? do i have to sacrifice a screw clamp thing so its nice and tight?
yes
touge rolla
Postby Jooce » Thu Feb 14, 2008 8:05 pm
ok so if i sacrifice the clamp that holds the pipe onto the blue connector then theres a chance the pipe might fall out of the blue connector.. ffs why dont they send you three clamps?!
Jooce
Postby FrEsH » Thu Feb 14, 2008 8:08 pm
use one of the clamps from your old factory intake
it's not rocket science...anything will do if you're REALLY in a pinch use a cable tie until tomorrow when you can buy a proper clamp.
BTW as above, your 99.9% likely to lose power with that setup, its gonna be sucking in toasty hot air straight from the engine
FrEsH
Postby Jooce » Thu Feb 14, 2008 8:20 pm
yeh my mrs old man is going to make me a cold air box.. he makes 4wd things so he reckons he can sort it out for me.. so ive put it back on and plugged in that air sensor. took it for a spin and it screams its ass off at high revs. sounds awesome..
Jooce
Postby AE82 FXGT » Thu Feb 14, 2008 9:32 pm
That small pipe sticking out between the sensor and pod, you'll want to plug that up as it will be sucking unfiltered air...
AE82 FXGT
Postby Bling » Thu Feb 14, 2008 9:33 pm
success then aye!
repco / local garage etc should have a hose clamp if you don't use the factory one off your old intake.
should only be a few bucks
Postby d1 mule » Thu Feb 14, 2008 9:36 pm
the "engine thingy" is the throttle body aka TB.
all good man, if nothing elst the pod and pipe will give you awesome the N/A scream :D
d1 mule
Shes looking good dude
Postby Phoenixkp62 » Fri Feb 15, 2008 11:25 am
Hey im the guy you brought that bad boy off....lol
PS that red DX that was behind you down lincoln rd was me.... ;)
good to see me old trueno in good hands keep up the good work!
Drop a turbo in her !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!lol :twisted:
It's more likey you'll get home by pushing a toyota than drive a honda.
Phoenixkp62
Postby Jooce » Fri Feb 15, 2008 5:20 pm
lol i was wondering who that was! hahaha
hey you dont have the silencer lying around for the exhaust do ya? im gonna need it for a wof!
Jooce
Postby Jooce » Fri Feb 15, 2008 5:21 pm
i tried using the factory clamp but it wont wind down far enuff.. so im guessing i gota buy another one..
Jooce
