Overheating issues
Overheating issues
Postby 20v_rollaboy » Tue Mar 25, 2008 10:14 pm
Car is a 1995 Corolla Wagon, 5efe engine, auto.
The car overheats :lol:
Ive replaced the water-pump, taken all hoses off and checked for blockages, checked radiator for blockages, checked everywhere for leaks, checked thermostat, checked radiator fan. Everything works.
After about 30kms of motorway driving, the temp gauge will go up. If I drive with the heater on the temp stays good/in the middle.
I have also done an oil change and have not noticed any water in the oil.
Help please :!:
20v_rollaboy
Postby method » Tue Mar 25, 2008 10:19 pm
How high does it go?
In my last car i set the thermostat so it wouldn't open until 100*C.
With the pressure the water is under and antifreeze its still a safe temperature for the water to be at.
PICS UPDATED DAILY
method
Postby sergei » Tue Mar 25, 2008 10:20 pm
most likely blocked radiator.
Warm up the car until the fan kicks in, then touch the bottom of the radiator and top and see if the bottom is cold, if it is cold and top is very hot that is a sign of blocked radiator.
Postby 20v_rollaboy » Tue Mar 25, 2008 10:31 pm
Ive let it get to 3/4 before pulling over and letting it cool down, but recently I have become used to driving with the heater on and the windows open.
Will check the radiator thing tomorrow, thanks Sergei.
20v_rollaboy
Postby sergei » Tue Mar 25, 2008 10:51 pm
Also how did you checked thermostat? did you put it in the boiling water to see if it will open?
Postby 20v_rollaboy » Tue Mar 25, 2008 11:35 pm
Yes, took it out and watched it open in just boiled water.
20v_rollaboy
Postby fangsport » Tue Mar 25, 2008 11:49 pm
loosen off the bolts on each hinge an install washers between the rear bolt and bonnet.
works real good, seemingly. and seeing as your car is overheating real bad, it would be proof that it dosn't work!! :twisted:
fangsport
Postby stalker » Tue Mar 25, 2008 11:50 pm
Done a compression test??
(guess it would be fine if there is no water in the oil) but worth a shot??
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby stalker » Tue Mar 25, 2008 11:51 pm
fangsport wrote:loosen off the bolts on each hinge an install washers between the rear bolt and bonnet.
:lol: :lol: :lol: :lol: :lol:
stalker
Postby fangsport » Tue Mar 25, 2008 11:55 pm
with engine running, check to see if compression is going into recovery bottle
fangsport
Postby 20v_rollaboy » Wed Mar 26, 2008 12:26 am
No, I havnt done a compression test, but if I cant find any other problems i will do one.
fangsport, do you mean to check if there is pressure on the hose going to the bottle?
I should also mention Ive replaced the radiator cap
LOL, yes we should all raise our bonnets so our engines will run cooler :roll:
20v_rollaboy
Postby fangsport » Wed Mar 26, 2008 12:43 am
20v_rollaboy wrote:fangsport, do you mean to check if there is pressure on the hose going to the bottle?
open the recovery bottle lid and see if there is compression bubbles .
fangsport
Postby stalker » Wed Mar 26, 2008 1:10 am
You say you have replaced the cap??
Please dont flame me for this as im not sure if this is true or not, but you did get the correct cap for it? I was told years ago that putting the wrong cap on can screw with pressure and stuff...but again, dont know if that could be true or not :oops:
stalker
Postby Dragger_Dan » Wed Mar 26, 2008 1:16 am
Damn, beaten to the punch. That was a perfect setup :lol:
Dragger_Dan
Postby cogent » Wed Mar 26, 2008 9:19 am
Yesssss do it! Please, for toyspeed?
Just 10 minutes work and a 20 minute drive will do it!
cogent
Postby pc » Wed Mar 26, 2008 9:54 am
sergei wrote:most likely blocked radiator.
I'd guess this too. I usually pull the radiator out and fire a hose in the top inlet. If the water doesn't rush out of the bottom in an unhindered manner, then it is probably blocked.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby 20v_rollaboy » Wed Mar 26, 2008 6:46 pm
Ok, I have just taken the radiator out, flushed it, and put it all back together. There were not any blockages in it, but there was some rust in the bottom of the main pipe going to the radiator.
On my way back home now, will see what happens.
20v_rollaboy
Postby 20v_rollaboy » Wed Mar 26, 2008 8:43 pm
Ok, problem is still here. No blockages in the radiator.
Short of doing a compression test, I am out of ideas :(
20v_rollaboy
Postby 85AW20v » Wed Mar 26, 2008 8:58 pm
I've had the same problem in my Lancer. I put a cooling system flush through, then pulled out the radiator and flushed it with a hose. Seemed to have good flow so refitted it but the problem was still there. Only way to fix it was get it stripped and cleaned at a radiator shop. Dropped the car off and $125 later, it was all sorted. It would be cheaper if you took your radiator out.
See ya
Simon
85 MR2 20v
85AW20v
Postby method » Wed Mar 26, 2008 9:07 pm
Lift your bonnet up a couple of inches?
It may work :wink:
PICS UPDATED DAILY
method
