Beams fuel rail
Beams fuel rail
Postby nz_climber » Thu Mar 27, 2008 4:30 pm
Hi there all, just looking at my engine the other night I noticed that the altezza engine only has one fuel hose through a regulator thingy into the fuel rail (on top of where the 3rd injector is).. anyone have a idea how this works? and can it be used like this with and external after market fuel pump?
Or would it be better to put an fuel into one end, then fuel reg and coming out at either other end or where fuel currently goes in.. any ideas?
nz_climber
Postby sergei » Thu Mar 27, 2008 4:59 pm
the fuel pressure regulator is in fuel tank, the "regulator thingy" is just a damper.
Postby nz_climber » Thu Mar 27, 2008 6:32 pm
ahh ok cool, makes a bit of sense now, just got to work out what I am going to do now..
nz_climber
Postby Celica RA45 » Fri Mar 28, 2008 11:22 am
bring fuel into the front bolt union no 1 injector and return line is near no 4 injector ,just put a toyota fuel regulator there .the fwd beams motors have this set up
Celica RA45
Postby nz_climber » Sat Mar 29, 2008 4:41 pm
cheers will do that, do all the 3sge's have the same regulator/pressure (I think the altezza one is 62psi?) or do I have to get a fwd beams regulator?
nz_climber
Postby Celica RA45 » Sat Mar 29, 2008 10:45 pm
any gen 2 or 3 will be fine fuel pressure on mine is a constant 45psi
Celica RA45
Postby nz_climber » Mon Mar 31, 2008 6:02 pm
thanks, that sounds good - I just want to confirm the fuel pressure of the standard altezza - as the ecu will be standard to start with
nz_climber
