Does anyone know the diesel codes to Corona wagons? Or is that the exception that breaks the rule?
origionally posted by ma71supraturbo:
You may have noticed people throwing around obscure letter/number combinations like JZA70, MA71, 1JZ-GTE, 7M-GE etc, but to you these codes mean nothing. If that is the case, look no further than this FAQ.
Let’s first start out with Toyota Chassis Codes. While they may seem totally random especially if you are comparing two different models, Toyota used a system fairly consistently that allows one to easily identify the vehicle and equipment based on each digit. Perhaps the most common Toyota chassis code belongs to the Toyota Corolla GTS (AE86). (In Japan, and in trendy US suburbs, people often abbreviate this to the “hachi roku” – Japanese for “8 6.”)
The "A" stands for the engine -- 4A-GE
The "E" is Toyota's chassis designation for the Corolla
The "86" is the chassis designation for those model years (1983-1987 Toyota Corolla GTS. The lower-grade model was called the 85 -- hachi-go -- in Japan).
Now look at another car from that time period sharing the same engine -- the 1st generation MR2 (AW11):
"A" for the 4A-GE engine
"W" for the MR2 chassis
"11" for the boxy chassis from 85-89
Here’s the 2nd generation MR2 (SW20 / 21):
"S" for the 3SG(T)E (the NA car had a 5S-FE in the US, but still was an "S" block)
“W” for the MR2 chassis
"20" or "21" depending on turbo or NA for 1991-1998
Starting to get the hang of it? Now lets move on to the 1st generation Supra (MA46 / 47):
“M” is for the 4M-E engine used in 1979-1980 (1981 engines got a 5M-E)
“A” is the Supra chassis.
“46” is for the 1979-1980 4M-E equipped Mk1’s, while “47” is for the 1981 models with the 5M-E
Second generation Supra (MA61 / 67, GA61):
“M” is for the 5M-GE engine, “G” is for the 1G-GE engine offered in other countries
“61” is the Mk2 chassis for non-US use, “67” were U.S. Mk2's (“61” can still be found on the chassis though)
Whew, time for our beloved Mk3’s (MA70 / 71, GA70, JZA70)
"M" for the 7M-G(T)E, “G” is for the 1G-GTE engine option in other countries, and “JZ” is for the 1JZ-GTE engine offered in other countries.
"A" is the Supra chassis
"70" was the 86.5-92 chassis (71 being turbo, but only on the VIN – at least in the US)
And the car that many of us love to hate, the 4th generation Supra (JZA80):
”JZ” for the 2JZ-G(T)E
“A” for the Supra chassis
“80” for the 93.5-98 body style (they did not delineate turbo/non)
So what about these engine codes? The first digit (a number) denotes the generation of the engine. The "M" series engine, for example, dates back to the Toyota 2000GT and had been used in many sporty/luxury cars for the better part of 30 years. Each new number denotes some change to the engine. For example, the Supra saw these “M” engines from 1979 to 1992:
4M-E 2.6 liter SOHC 2-valve head (1979-1980)
5M-E 2.8 liter SOHC 2-valve head (1981)
5M-GE 2.8 liter DOHC 2-valve head (1982-1986)
6M-GE 3.0 liter DOHC 2-valve head (not used in Supras, but found in JDM Crowns in the mid 80’s)
7M-G(T)E 3.0 liter DOHC 4-valve head (1986.5-1992)
In contrast, the "JZ" series only has two versions to date (and by the looks of current trends, probably will only have two):
1JZ-G(T)E 2.5 liter DOHC 4-valve head (1991-1992 – but used later in other models)
2JZ-G(T)E 3.0 liter DOHC 4-valve head (1993.5-1998 – also used in other models)
Typically Toyota will stroke an engine to achieve a new block number, but often head changes go along with it. For example, the 1JZ head actually flows better than the 2JZ head, but isn't as nice on emissions. Since the 2JZ was coming to the states, the head had to be changed…
The next digit(s) (a letter/ letters) in the engine code refers to the block itself. "M," "A," and "S," are examples of single digit blocks. Toyota started using two digit block names in the early 90's including: “JZ” and “UZ” (Toyota/Lexus V
The next digit (the first after the dash) designates the head design. "G" is the DOHC performance head, generally with a more aggressive valve angle for higher rpm/more power. "F" is the low-end torque and fuel-efficient DOHC head, with less aggressive valve angles. If there is neither an “F” or “G” in that digit, then the engine is a SOHC model (probably chain-driven). Toyota did make a few OHV engines, but they are much older and by now quite rare.
The next digit is for forced induction. "T" denotes a turbocharged model, but unlike Nissan, Toyota does not add an extra "t" for twin turbo versions. If the engine is supercharged (88-89 MR2 and some Toyota Previa Minivans, for example), it will have a “Z” instead.
The last digit "E," means the car has electronic fuel injection. If the “E” is missing, the car is carbureted.
A recap of the M-series history:
4M-E 2.6 liter SOHC 2-valve head with EFI
5M-E 2.8-liter SOHC 2-valve head with EFI
5M-GE 2.8-liter DOHC 2-valve head with EFI
6M-GE 3.0 liter DOHC 2-valve head with EFI
7M-G(T)E 3.0 liter DOHC 4-valve head with EFI
Another example is the “22R” engine commonly found in older four cylinder Toyota Pickups. If the engine is a 22R-E, it has EFI. If it is just a 22R, you’re stuck with a carb.
There are also a few archaic designations that you might come across, especially if the engine is from the late 70’s or early 80’s. A “C” in the engine code means that engine met California emissions requirements (e.g. 4A-GEC). An “L” in the engine code means that engine was mounted transversely (e.g. 4A-GELC). And a “U” means that engine was equipped with an oxygen sensor so it could only be run on unleaded gas (e.g. 4A-ELU).
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
xsspeed wrote:so whats the diff between ae80/81/82? different specs?
darkwolf wrote:We also got into if somebody takes a 4A-GE and adds a turbo does this then change the engine code (bearing in mind there have been no other modifications) or is it simply a 4A-GE with a turbo?
I could argue both sides here but I don't think I'd win either
Users browsing this forum: Bing [Bot], Google [Bot] and 54 guests
