EP71 engine questions
Postby slighty_looney » Sun Apr 06, 2008 11:56 am
Hey guys, i wouldnt mind abit of advice on making my runabout starlet have abit more go in the future. i got a EP71 (1.3 fuel injected 4 door model) just wondering what motors would drop in with the budget expence :P i know that i could get the turbo model off this year and drop the motor in but would a later model gt motor fit in without much effort? what about a 4age if i decided to stay non-turbo, also gbox advice and what not, surely someone has done somethink with there little cars before, and no i dont wana google it :P hands on advice is what im after, cheers
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby 20v_rollaboy » Sun Apr 06, 2008 3:35 pm
4age will need chassis modification, so dont think you will want that for a daily.
4efte will drop in however, my mate has one with a t3 turbo setup, goes nuts:)
If you really want good advice, go to www.starletcentral.co.nz lots of fine examples there.
20v_rollaboy
Postby Dell'Orto » Sun Apr 06, 2008 4:16 pm
Realistically, if its a daily you arent wanna have it off the road too long so I wouldnt bother with an engine swap. Just get your old man to knock up some extractors for it, make a good cold air intake and get the cam reground for a laugh ;)
Postby slighty_looney » Sun Apr 06, 2008 4:59 pm
4efte are outa the same shape? would i just need to do engine loom and ecu ? lol yea brad that'd b a laugh it goes ok for what it is, already gota filter on it ;) haha but yea daily but it'd b cool to turbo it,
FC3S
slighty_looney
Postby 20v_rollaboy » Sun Apr 06, 2008 5:37 pm
No, 4efte are from the ep82/ep91.
The turbo motors from your shape are 2e-t's i think.
20v_rollaboy
Postby slighty_looney » Sun Apr 06, 2008 6:07 pm
so if i got a 4efte would it bolt up to my gbox or would i need new gbox and shafts? what bout loom and ecu? sorry to be a pain with all the questions
FC3S
slighty_looney
Postby DexGT » Sun Apr 06, 2008 7:17 pm
A 4E-FTE will bolt up to your gearbox , how long your box lasts is another story. Best to get the FTE box with the motor if posible . The block is the same so just bolt the mounts off the current motor to the new one , sort the loom out (easilly the hardest job in this swap ) , sort the exhaust out , and I think you will have to front mount the intercooler , others will be able to say if the top mount IC fits under the 71 bonnet , but I'd be surprised if it does .
Good luck with the transplant :)
DexGT
Postby slighty_looney » Mon Apr 07, 2008 11:55 am
yeah im not doing it anytime soon just wanted to see what it would take, steel fab wont be a problem. that other gearbox that ur talking about would that use the same shafts as what are in the car now? and yes i would front mount it as the steel fab isnt a big issue
FC3S
slighty_looney
Users browsing this forum: Google [Bot] and 24 guests
