Who's bought a de-registered car?
Postby Volatile » Sat Apr 12, 2008 9:20 pm
Ok so I'm looking at a GTZ where the owner has let the registration lapse.
What do I need to know?
I assume that you don't/can't do a change of ownership?
What do you do?
James
Volatile
Postby l1ttle_d3vil » Sat Apr 12, 2008 9:22 pm
i have, but haven't gone through the re-reg process yet. so far ive got a letter from the guy stating I've bought the car, seeing as you can't do a change of ownership.
other than that you need some proof that it was previously registered, I'm not sure exactly what - the original number plates might be enough?
Postby Bling » Sat Apr 12, 2008 9:42 pm
depends what you are wanting to do with the car i guess...
nothing if you are just going to wreck it i'd imagine
Postby Matty104 » Sat Apr 12, 2008 10:20 pm
i have but also havent gone through complience yet ,
but ringing around quite a few places gave me the idea that you need a letter from the owner stating that you brought the car and original number plates , but i don'tt think they will be 100% worried about the plates , other than that it just needs to be up to standard and give them some of your money and they should be happy
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby ChaosAD » Sat Apr 12, 2008 10:37 pm
Ive done it, waste of money. Part the car out and buy one with rego, or reshell it.
ChaosAD
Postby ChaosAD » Sat Apr 12, 2008 10:39 pm
Has it been deregistered? or is there just rego owing on it?
ChaosAD
Postby l1ttle_d3vil » Sat Apr 12, 2008 11:34 pm
ChaosAD wrote:Ive done it, waste of money. Part the car out and buy one with rego, or reshell it.
care to elaborate on that at all? what was the car you revinned?
Postby Jdawg » Sun Apr 13, 2008 1:07 am
Around 400 for your recompliance and 330 for 12 months reg.
If it has the old WOF sticker still on the windscreen, that will have the plate no.
If there is any body damage or rust fix it first or you will have to get a repair cert, another 400
If the figures add up, do it
Jdawg
Postby Mr Revhead » Sun Apr 13, 2008 1:47 am
yeah, basicly if its had ANY structural repair on it before, forget it.
they will want a repair cert for it. good luck getting a repair cert for old work....
if its really tidy and had no damage or issues, then it could be worth it.
but if its had a ding or rust etc it wont be.
Postby Volatile » Sun Apr 13, 2008 9:56 am
Ideally I want to be able to re-register it. The reg has been expired for more than two years and not been on hold.
So basically if it hasn't been in a big stack and in good condition then it's be about $1500 to get it back on the road?
Volatile
Postby Matty104 » Sun Apr 13, 2008 10:02 am
is it that hard to get a rust cert rev?
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Jdawg » Sun Apr 13, 2008 11:12 am
Volatile wrote:Ideally I want to be able to re-register it. The reg has been expired for more than two years and not been on hold.
Visit a compliance center, most will give good free advice, including giving you a list of certified repairers, who will normally also give your car a quick once over for free to let you now how much for repairs.
If the car can pass a WOF now and has not had/ need any repairs it will be around 500 to get it all done, reg'd and wof.
Jdawg
Postby Mr Revhead » Sun Apr 13, 2008 11:14 am
its not hard.... it just has to be done right
you cant just fix it at home and have them ok it.
best thing to do is talk ot the guy who will be re vinning it.
if its had previous repairs they require those repairs to be certed. and you probably wont find anyone willing to cert old repairs... it will have to be redone
edit: good advice above
Postby rolla_fxgt » Sun Apr 13, 2008 11:35 am
Mr Revhead wrote:its not hard.... it just has to be done right
So the moral of the story is when it has repairs done get them signed off when it happens for cases like this in the future?
rolla_fxgt
Postby ChaosAD » Sun Apr 13, 2008 11:36 am
As above. Had to chip all the bog out to get a repair cert for previous repairs.
Things like brake pads, brake lines etc all have to be well above wof standard.
ChaosAD
Postby Mr Revhead » Sun Apr 13, 2008 11:41 am
you could do.... but it would be easy to just not let the rego lapse!!
Postby Looonie » Sun Apr 13, 2008 8:02 pm
I re-vinned my old supra. Probably the exception to the rule because the body was so absolutely immaculate. Otherwise you're usually better off just buying a wof/reg car unless its ridiculously cheap or something...
I replaced all the brake rotors, pads and fluid in the supra. Also replaced all the diff and gearbox oil then took it for its re-vinning stock as a rock.
I think they bounced it on a couple of small things like bulbs etc. But be aware that unless you know what you're doing with the car, it may get bounced on heaps more stuff... suspension arms, bushes, wheel bearings etc.
This was about 3 years ago, but it cost me $450 for the check and another $160 for 6 months rego from memory. So its around $600-$700 to do it (you can choose 6 or 12 months rego when you do it), price may have gone up a little.
Is the car you're getting stupidly cheap and still absolutely mint condition in and out or is there another reason you're considering it?
Most of the cars I've seen on trademe that are de-reg aren't worth buying to put back on the road because people only sell them for a few hundred less than a wof/reg example. So factor in probably at least a grand on the purchase price to put it on the road, assuming theres nothing seriously wrong with it (panel/chassis damage etc).
Rumple dee pumple dee doo...
Looonie
Postby Lloyd » Sun Apr 13, 2008 9:00 pm
ChaosAD wrote:Things like brake pads, brake lines etc all have to be well above wof standard.
No so much "above standard" as much as "has the right numbers on it".
We take plenty of bloody good brake pads out of vehicles coming in and you can put $10 Silverline pads in if you want which don't work as well, wear out quicker and fade like mad but are compliable.
(For the record, we don't use those cheap sh*te pads)
Postby l1ttle_d3vil » Mon Apr 14, 2008 9:14 am
Looonie wrote:This was about 3 years ago, but it cost me $450 for the check and another $160 for 6 months rego from memory. So its around $600-$700 to do it (you can choose 6 or 12 months rego when you do it), price may have gone up a little.
last time I checked - a bit over 6 months ago - it was $250 for the revin.
Postby fuel » Mon Apr 14, 2008 12:17 pm
Depends on the age and engine size of the car. I think if it's pre 1990 it's a bit cheaper as it doesn't have to be stripped down so much. Also if it's above 3L or 3.5L (can't remember which) it's more expensive still. I think if it's diesel the price is different again.
Some good info here - http://www.oldschool.co.nz/phpbb/viewto ... =1&t=12930
LOUD NOISES!!!
fuel
