Exedy Racing Clutches
Postby Stu- » Fri Apr 11, 2008 9:20 am
Has anyone had any experience with the Exedy Racing clutches?
They are apparently the next one up from the Sports Tuff Heavy Duty unit with the difference being the Sports Tuff HD uses a standard cast steel pressure plate that is uprated in Australia then rebranded where as the Exedy Racing pressure plate is made in Japan and isn't cast steel. Also I've heard but can't confirm that the Exedy Racing pressure plate is a two piece unit...
I'm basically after the strongest clutch possible for a 212mm 20v 4age flywheel without going twin plate (which I can't afford).
Any info or experience would be great.
Thanks
Project Thread
Stu-
Postby tsoob » Fri Apr 11, 2008 10:30 am
i have the exedy 3 puck clutch with 1900 pound fly wheel, its the best clutch ive ever had, 200kw at the wheels and not even a hint of slipping can dump it in 2nd and bake up even got it into 3rd with my old tyres on it!!
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Stu- » Fri Apr 11, 2008 11:42 am
Do you know if its the Sports Tuff or Race one?
Project Thread
Stu-
Postby themaleman » Fri Apr 11, 2008 8:52 pm
the good people at midus that changed my clutch said mine was a 'heavy duty racing clutch'. its a 3 puk exedy clutch and steel presure plate. had it for many a moon(bout 2 years) on my 4agze, and its still got quite a bit of meat on in. never slipes eaither
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Looonie » Sun Apr 13, 2008 7:46 pm
Can't advise on whether the racing clutch is made in japan...
But do not... I repeat DO NOT EVER buy something from Exedy Australia.
They are complete $&#$% tools.
I put a sports tuff kit into the soarer when I originally did the conversion... piece of shit couldn't hold two bits of paper together if they were glued! Absolute $&#$% useless.
It was just a stock clutch plate with the friction material removed and replaced with "pucks" with huge oversized rivets... and I doubt the pressure plate was even uprated. Absolute shit. A stock 236mm clutch worked better than that piece of crap.
So yeah... normally you can see from the box whether the item originates from Japan or Australia.
Best bet would be to go see Eugene at Trade Parts. While he may think he's right when he's wrong and argue with you until you bring the part in and prove it to him, he has the good gear :)
Rumple dee pumple dee doo...
Looonie
Postby escortman » Sun Apr 13, 2008 8:56 pm
have u looked into RPM clutchs appco sell them, with my discount got 4puk semisolid center clutch plate and upgraded pressure plate cost 300 buks
4x4 toyota blizzard offroader
escortman
Postby method » Sun Apr 13, 2008 11:04 pm
escortman wrote:have u looked into RPM clutchs appco sell them, with my discount got 4puk semisolid center clutch plate and upgraded pressure plate cost 300 buks
they are pretty average.
Mine was 250 for a 4 puck and upgraded pressure plate and it will slip when trying 3rd gear skids :lol:
Good for normal driving and a little fun but if its a car you only use for "having fun in" get something better.
PICS UPDATED DAILY
method
Postby escortman » Mon Apr 14, 2008 7:29 am
u reckon? my cars done a few 3rd gear skids easily and never slipped
which 1 do u have theres 4 to choose from
escortman
Postby no_8wire » Mon Apr 14, 2008 11:26 am
here the one I got...
3 puk with 3000lb pressure plate
Heaviest one I could get without going twin plate. Cost about 600-700?
no_8wire
Postby Stu- » Mon Apr 14, 2008 2:54 pm
Thats the bugger I'm after. What size flywheel are you using? Who did you get it through?
Project Thread
Stu-
Postby no_8wire » Mon Apr 14, 2008 3:04 pm
212mm flywheel (this was a 4age clutch but fits on my 4afe flywheel)
Cant remember where I got it, ring Partsmaster in Henderson as they recommended the place I ended up getting it from. Just tell them what sort of HP etc you want to be running.
no_8wire
Postby Stu- » Mon Apr 14, 2008 3:58 pm
I gave them a call but they weren't able to give me any information or pricing. They said to send an enquiry via their website. Might give another branch a call instead.
Project Thread
Stu-
Postby themaleman » Mon Apr 14, 2008 5:22 pm
thats the same as mine, pity i never souced it myself
4agte ae92 Levin
a15 powered sj410
themaleman
Postby tatsumaki » Mon Apr 14, 2008 5:40 pm
If you are prepared to look at something different Stu, I recommend you contact Anton at Geartech down here.
I can give you the details if needed.
On the other hand if you need to stay with Exedy (the JDM version) then you could always buy a TRD unit. Exactly the same.
Paul.
tatsumaki
Postby Stu- » Mon Apr 14, 2008 7:16 pm
Depends on how much unfortunately - budget is pretty tight else I'd go to a twin plate. But send me the details and I'll see what they can do.
Project Thread
Stu-
Postby IH8TEC » Mon Apr 14, 2008 7:23 pm
i'd love to see that actually pressure tested at 3000lbs
Postby Bazda » Mon Apr 14, 2008 8:28 pm
yea same here, I dont think you can ever get a 3000lbs in 212mm and also in the 4agze 225mm, the most I could ever get was around 2000lbs. Due to the design of the pressure plates.
http://www.erzperformance.com/product_p ... ge2-93.htm
http://www.erzperformance.com/product_p ... ge2-94.htm
Postby Bazda » Mon Apr 14, 2008 8:38 pm
maybe you shoudl go for something like this Stu
http://www.exedyusa.com/race/TH01SD
And get the MR2 turbo disc to suit. As the MR2 turbo disc spline is the same as the 4agze.
Postby IH8TEC » Mon Apr 14, 2008 8:47 pm
and also note the design of that last pressure plate is alot different to the one you have shown that most of us run, hence the higher clamp pressure,
Postby no_8wire » Mon Apr 14, 2008 9:44 pm
Bazda wrote:yea same here, I dont think you can ever get a 3000lbs in 212mm and also in the 4agze 225mm, the most I could ever get was around 2000lbs. Due to the design of the pressure plates.
mmm I just going off what I asked for and what the guy told me he had in stock. Said on the box 1300kg = 2870lb roughly 3000lbs
Any place you can take them to get it tested?
no_8wire
