how do i adjust a clutch
Postby Matty104 » Mon Apr 21, 2008 8:36 pm
as the title says,
trying to get the ke going and the clutch doesnt seem to disengage, looking at the fork when it travels as far as the pedal will take it, it still has about 25mm of travel before it cant go any further, ive adjusted the circlip as far out as it can go for it to be like that
is there a way i can adjust it more?
hope that makes sense ,
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby bluemaumau » Mon Apr 21, 2008 8:53 pm
is it hydraulic?
back of the clutch pedal?
Postby Matty104 » Mon Apr 21, 2008 9:11 pm
na its cable , whats on the back of the clutch pedal to adjust?
its a 74 ke20,
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby matt dunn » Mon Apr 21, 2008 11:02 pm
Has the car been sitting for quite a while?
I put a s/h 4k and box complete into a KE70 and the clutch would not disengage but had pedal movement,
was just the plate was kinda rusted/seized onto the surfaces.
I started the car in gear and drove with the clucth depressed and loaded it up with the brake pedal till it broke free,
from then on it worked perfect till I sold it.
Postby Lloyd » Mon Apr 21, 2008 11:06 pm
Usually you can just pull on the cable outer thats sticking out the firewall and put the circlip on. How far out does it pull? Should be really free to poke in and have some resistance before you get to the last bit for putting the clip on.
Wrong clutch fork maybe?
Postby Matty104 » Mon Apr 21, 2008 11:28 pm
clutch etc hasnt been going for a good 6 months , but i had the clutch and flywheel all apart the other day to put it onto the 4k,
clutch fork seems to be right as it all came out of a running starlet,
the clip is on the last avalable slot on the cable, but i can feel the thrust bearing hitting the prssure plate prongs, and when i pull it by hand it feels like it releases the clutch plate, but yea just when putting the clutch in it wont pull the full distance,
i kind of understand what you are saying there HRT , so the plastic outer is supposed to slide in and out and is locked in place by the clip?
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Lloyd » Tue Apr 22, 2008 12:20 am
Is the clutch fork actually moving when you are pushing on the pedal? Did you put the clutch plate on up the right way?
Postby Matty104 » Tue Apr 22, 2008 12:24 am
yes it moves and the thrust bearing hits the prongs and compresses them a small amount and then my foot hits the floor , so what i need it to do is hit the pressure plate prongs earlier when im putting the clutch in,,
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Bling » Tue Apr 22, 2008 1:15 am
did you install the engine etc yourself?
might need to pull the clutch cable further through the firewall towards the front of the car as HRT describes.
had a similar issue with mine
Postby Mr Revhead » Tue Apr 22, 2008 11:46 am
is the clutch pedal level with the brake pedal?
Postby Matty104 » Tue Apr 22, 2008 7:12 pm
Mr Revhead wrote:is the clutch pedal level with the brake pedal?
i just realised that its not, im a bit of a noob when it comes to all this stuff , its my first project so im just learning
i took some rather bad quality photos , but they should show what im meaning
cable coming out through fire wall
clutch cable going to the fork
pedal sitting to high
hook where ther cabe attatches to the clutch pedal
'Tron E30 Massif
89 BMW 325sci
Matty104
