hey,
as title says does any one have the info hand for the torue settings for pressure plate to flyheel?
cheers shaun
method wrote:Duh obviously, but you totally missed my point. What i was getting at is you would want different torque for a 1,000lb and a 3,500lb pressure plate wouldn't you?
1hypo3 wrote:method wrote:Duh obviously, but you totally missed my point. What i was getting at is you would want different torque for a 1,000lb and a 3,500lb pressure plate wouldn't you?
huh?are you talking bolt torque or engine torque? im confused!
method wrote:1hypo3 wrote:method wrote:Duh obviously, but you totally missed my point. What i was getting at is you would want different torque for a 1,000lb and a 3,500lb pressure plate wouldn't you?
Torque on the bolt!
i.e, more than 19nm.
Yeah was meaning due to more force from the heavier pressure plate.
A 3,500lb pressure plate has nearly 3 times the clamping pressure of a standard pressure plate and would also put 3 times the tensile force on the bolts.
So i figured bolt torque and/or grade would depend on pressure plate. 19nm for a standard plate as in the manual but more for a heavier one.
And as you said you'd need larger bolts or a bolt made from a higher grade.
Understand what im saying??
I know nothing, im just bringing up a point that crossed my mind when i thought of it.
