Doing a 4age AE101, auto to manual conversion
Postby 4-AGE 4-LIFE » Tue Apr 29, 2008 4:31 pm
I have almost finished my auto to manual conversion, 2nd one i have done.
I have completed.
manual gearbox fitted.
clutch lines and pedels fitted.
M/T ecu fitted - I have rewired the auto loom plugs to suit the M/T ecu, using the pin diagrams from (http://www.club4ag.com/technical_main.htm)
now ready to start the car.
But i have all ACC power, then I turn the key to ON position and no dash lights come on, the starter will not crank.
any ideas??
Thanks for your help.
Ben.
Ben Threadwell
Exsus Automotive
Suspension specialists
4-AGE 4-LIFE
Postby 20v_rollaboy » Tue Apr 29, 2008 9:29 pm
What did you do with the plug that went to the auto box?
Do you know that you didnt have to change the ecu??
20v_rollaboy
Postby Mr Revhead » Tue Apr 29, 2008 9:48 pm
sounds like you didnt quite sort the wiring right....
go back through it all!
or, but it all back they way you found it!
Postby 4-AGE 4-LIFE » Wed Apr 30, 2008 10:49 am
no i didn't know i didn't need to change the ecu,
the 2 plugs from the auto box are still attached to the loom, is there a way I can keep the auto ecu.
I will go through and check the wiring again today.
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby pc » Wed Apr 30, 2008 1:09 pm
When I did this conversion on an AE82 I kept the Auto ECU and made up one of these.
The plugs on the left have been cut off the old auto box and plug straight into the existing loom.
The plug on the right was a spare on the loom that I think went to the fluid level indicator on the auto box, either way it wasn't needed so I used it for the reverse lights switch.
I'm assuming an AE101 will be similar.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby 4-AGE 4-LIFE » Thu May 01, 2008 10:17 am
thanks for those photos pc.
I just finished checking the wiring again, worked out good.
I also checked the pins in the ecu, to the diagrams online.
but still no luck :(,
could this mean the ecu is stuffed. anyone else got any ideas?
Thanks again.
Ben.
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby KwS » Thu May 01, 2008 11:18 am
stupid question, and might be moot with that mt ecu.... but did you short the inhibitor to always be in neutral?
KwS
Postby 4-AGE 4-LIFE » Thu May 01, 2008 12:51 pm
no i havn't shorted the inhibitor to allways be in neutral
the main problem i have is no ON power with the key, I have the ACC power
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby RS13 » Thu May 01, 2008 2:38 pm
4-AGE 4-LIFE wrote:no i havn't shorted the inhibitor to allways be in neutral
Is it like trying to start an auto car in 'Drive'? Cars have inhibitor circuits that prevent the ignition starting when the auto shifter isn't in Park or Neutral. When you convert a car to manual, you need to loop (or "short") the inhibitor wires together so that the car thinks that its' in Park or Neutral, and allows power to the ignition. A common mistake, but easily fixed.
RS13
Postby 4-AGE 4-LIFE » Thu May 01, 2008 4:46 pm
Yeah it is like trying to start it in drive, but having no dash lights or the engine check light come on. Feels a bit odd to me.
Where would I find these wires for the inhibitor switch any ideas?
Ben.
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby 4-AGE 4-LIFE » Thu May 01, 2008 5:00 pm
Should I wire these 2 wires here together?
or am I on the wrong track?
[img][img]http://img87.imageshack.us/img87/1294/ae1014age20vecubcv3.th.jpg[/img][/img]
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby RS13 » Thu May 01, 2008 5:08 pm
4-AGE 4-LIFE wrote:Yeah it is like trying to start it in drive, but having no dash lights or the engine check light come on. Feels a bit odd to me.
Ben.
Lol sorry dude, I've never converted an AE101, only Nissans.. not much help, I'm sure someone else can assist you. :)
RS13
Postby Calvin » Thu May 01, 2008 5:28 pm
4-AGE 4-LIFE wrote:Should I wire these 2 wires here together?
Wrong
Here
Circled is a plug on the loom. it plugs into the auto box and is attached to a switch. the switch is closed when in park and open when out of park.
when the loom plug is unplugged it is a open circut therefore the car thinks it is gear and wont start. cut the plug out of the circut and you should be good to go...
Calvin
Postby Mr Revhead » Thu May 01, 2008 5:39 pm
i think you both posted the same thing! :lol:
Postby 4-AGE 4-LIFE » Thu May 01, 2008 5:41 pm
awsome
I actually wired it up how i showed in the red circle
and car runs good
omg I feel like a idiot, i just never stared at them in boredem long enough to figure it out.
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby Calvin » Thu May 01, 2008 5:49 pm
Mr Revhead wrote:i think you both posted the same thing! :lol:
lol yeh. now that i look at it
Calvin
Postby pc » Thu May 01, 2008 5:52 pm
Didn't my photo show that? :lol:
red car
Manfield - 1:24s
pc
Postby 4-AGE 4-LIFE » Thu May 01, 2008 7:43 pm
yes your photo showed that, but it confused me :oops:
i just bypassed the switch at the ecu pins
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby importcustoms » Fri Jun 20, 2008 4:24 pm
sorry to bring up and oldish thread but im having issues with my inibitor and ive been left with a mess from the last owner of the car...
anywho random wires have been cut surrounding the plugs i need and none match the colours above...
there is evidence of a plug being cut off next to the starter signal terminal these three wires are brown with a yellow trace, blue with a yellow trace, purple with spotted red trace all of which are small wires...
next i have three white wires a black wire with an orange trace (white and black wires are thickish) and 2 black wires with a red trace, then there are 2 long black wires one with a brown speckled trace these are all around the reverse switch
after trying to locate plugs similar to those in the pics the only thing i found that slightly resembles them are ..
a yellowy transparent plug which has 2 thickish wires which are black and black with a white trace and a smaller red with a black trace ... this plug is located next to the cut three wire plug mentioned above..
and a white plug which has a light green wire, light green with a red trace and a red with a blue trace
there are a lot more left over plug but they just dont seem relevant to the above diagram
can anyone make sence of that and relate it to the diagram above that would be awesome... also the car is a ae82 NZ new sedan
thanx Riki
[Admin Edit: oversized image/commercial advertising removed]
importcustoms
Postby pc » Sat Jun 21, 2008 11:21 am
got pix?
red car
Manfield - 1:24s
pc
