Removing a SC
Removing a SC
Postby Calvin » Thu May 01, 2008 4:04 pm
FROM PEOPLES EXPERIENCE.. is it possible/troublefree to remove a SC while the engine is in the bay.
or
Is it better to pull the motor out
Does anyone have any better ideas ? or suggestions
Motor is of course 4agze bigport in ae92 gtz and will be removing supercharger to put n/a intake for 4agte
Cheers[/b]
Calvin
Postby bluemaumau » Thu May 01, 2008 4:16 pm
you pretty much need to take the inlet side off. you can leave some of it but its easier to remove the whole inlet
Postby Calvin » Thu May 01, 2008 5:16 pm
bluemaumau wrote:you pretty much need to take the inlet side off. you can leave some of it but its easier to remove the whole inlet
I dont think you read my question properly
Calvin
Postby Distrb » Thu May 01, 2008 5:18 pm
It is troublesome to do it either way. it is possible to do it with the motor in place.
personally i'd do it with the motor in place. Dont pull the motor if you dont have to
Distrb
Regular Poster
Postby Calvin » Thu May 01, 2008 5:31 pm
Thanks Distrb...
Anyone else want to add their two cents
Calvin
Postby bluemaumau » Thu May 01, 2008 5:59 pm
yea if all your doing is removing the inlet side and replacing with N/A stuff, id do it in the car.
Postby Calvin » Thu May 01, 2008 6:29 pm
bluemaumau wrote:yea if all your doing is removing the inlet side and replacing with N/A stuff, id do it in the car.
Cheers :)
Calvin
Postby Mike- » Thu May 01, 2008 6:54 pm
yeh in the car is the go, just need a small 10mm spanner or small socket set for the inlet pipes
Mike-
Postby themaleman » Thu May 01, 2008 7:34 pm
if it were me i would remove the engine, but thats cause id get f#$ked off with the space avalible in the engine bay.
i take it your exaust manifold will be coming off anyway so it will have to be unbolted regardles.
unhooking/reconecting the loom is easy, and fluids can saved and reused.
might find your mounts need replacing iswell.
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby evil_si » Thu May 01, 2008 8:21 pm
its not to bad to do in place,
need a decent 14mm tube socket and power bar to undo the lower mount bolt
it is easier to remove the inlet manifold to get to some of the bolts, but not absolutely nucessary
evil_si
Postby escortman » Thu May 01, 2008 8:41 pm
o mate its an anbusolute slut me and mate did it man took for ever just kept finding bolts holding something on holding something else on
4x4 toyota blizzard offroader
escortman
Postby Calvin » Thu May 01, 2008 10:10 pm
escortman wrote:o mate its an anbusolute slut me and mate did it man took for ever just kept finding bolts holding something on holding something else on
yea i can imagine what you mean. Anyone got any useful tips....
Calvin
Postby escortman » Fri May 02, 2008 12:23 am
maybe a useful tip dont drink heavily the night before :lol:
thats all i got really cant remember much was just over a year ago i ditched the sc
escortman
Postby tsoob » Sat May 03, 2008 5:58 pm
escortman wrote:maybe a useful tip dont drink heavily the night before :lol:
haha when i removed the motor from my car i was drinking heavily, its kinda blurry but when i woke up in the morning it was on the crane!
for this job, are you planning on doing anything to the bottom end or just replacing the s/c??
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
