coil packs
coil packs
Postby ke_25 » Mon May 05, 2008 11:31 pm
het just bout to purchase coil packs for 4agte, and woundering what people are running?
will be unning g3 link, havent purchased igniter as yet looking into best options, or amy one run wasted spark?
cheers shsun
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby strx7 » Mon May 05, 2008 11:47 pm
mitsi twin cam W/S coil packs from a 4G63/4G67 or similar with the corrosponding ignitor
Postby Crampy » Wed May 07, 2008 6:11 pm
Same with me. I'm using a EVO3 ignitor and will be running some Mitsi coils I got from Pick A Part for $11 :lol: :lol: Cheap cheap.
At the moment it's go the stock 4AGZE coil packs, but I'll be changing to the Mitsi coils, so I can use my MSD leads.
This is with a Link V5.
Crampy
Postby Distrb » Wed May 07, 2008 8:57 pm
I'm running Galant coils and igniter, with a Link G3.
I'm sure you can run the Link igniter, or the mitsi one, up to you
Distrb
Regular Poster
Postby ke_25 » Wed May 07, 2008 9:56 pm
kool thanks for reply,
ke_25
Postby tsoob » Wed May 07, 2008 11:27 pm
$&#$% that man run bosch individual coils, mine has a smaller turbo than a lot of other guys and makes as much power, i put a lot of it down to the coils, you should come check out the car on saturday at our dyno day.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby ke_25 » Wed May 07, 2008 11:48 pm
wat coils you running? ive ceen evo coild run on alot of higher powered motors, esp in the orig 4g63 abdstill coping
ke_25
Postby tsoob » Thu May 08, 2008 12:04 am
they are individual bosch coil packs, they came with the microtech computer, evo ones are good, the individual ones will make more tho.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby ke_25 » Thu May 08, 2008 12:05 am
are you running a lt10 or link
ke_25
Postby tsoob » Thu May 08, 2008 12:07 am
lt 10, 194.4 kw on 16psi with moe to come on sat after new head goes on.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby ke_25 » Thu May 08, 2008 12:08 am
oh ok, thats prity good, im tossing between link and lt10, heading down link path i think.
ke_25
Postby Crampy » Thu May 08, 2008 1:52 am
tsoob wrote:$&#$% that man run bosch individual coils, mine has a smaller turbo than a lot of other guys and makes as much power, i put a lot of it down to the coils, you should come check out the car on saturday at our dyno day.
I'd put that down to the tune or the dyno rather than just the coils.
Crampy
Postby tsoob » Thu May 08, 2008 9:19 am
yep tune plays a huge part, but the massie spark and gap on the plugs really helps. took a fair bit of timing out of it also, runs pretty sedate off boost then whammo it hits limit before it stops making power.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby IH8TEC » Thu May 08, 2008 1:14 pm
it's not gonna make much more power, like crampy said, it's mainly a tune not coils, mitsi coils are very good, and provide a very strong spark, thing with individual coils is you dont have to run wasted spark. but thats a minor difference unless you got sh1t tonnes of power.
Postby ChaosAD » Thu May 08, 2008 8:28 pm
Does anyone know what leads will fit a silvertop and evo coils?
Was told generic ones would work but would prefer to use proper twin cam ones.
Are the evo, gsr or diamante ones the right length/diameter?
ChaosAD
Postby Crampy » Fri May 09, 2008 7:22 am
ChaosAD wrote:Does anyone know what leads will fit a silvertop and evo coils?
I'm using a set of MSD leads for a B16A Honda motor. They're a good length, so I can put the coils away from the head. The mitsi coils will let you use pretty much any lead, without that stupid clip like the 20V leads and W/S 4AGZE leads have.
Crampy
Postby ChaosAD » Fri May 09, 2008 8:33 am
Is the tube on the leads that goes down the center of the head the right length/diameter? or do you need to trim it up?
ChaosAD
Postby Distrb » Fri May 09, 2008 8:51 am
use set of eagle leads. part no. E74295. fits both the 20v head and mitsi coils perferctly, whilst giving you plenty of lead length too..
Distrb
Regular Poster
Postby ChaosAD » Fri May 09, 2008 1:26 pm
Wicked, thanks for that Distrb
ChaosAD
Postby bluemaumau » Fri May 09, 2008 4:51 pm
who has eagle leads?
