DYNO DAY !!
DYNO DAY !!
Postby tsoob » Mon May 12, 2008 6:49 pm
The link in my sig will take you to some of the pictures from saturday.
The day was huge success and we are all excited about running another event in the future.
They dyno is still here, so if anyone is after some tuning this week please let me know.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby tsoob » Mon May 12, 2008 7:02 pm
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
RESULTS
Postby tsoob » Mon May 12, 2008 7:20 pm
Here are the results of our dyno day in order from most to least KW these are measurements at the wheels on a dynapack
1st 2003 FORD FPV (RACE GAS) MAXED THE DYNO ON 2ND RUN 333.4 KW
2nd 1980 HOLDEN KINGSWOOD UTE 265 KW
3rd 1991 S13 (RB25DET) 243.8 KW
4th 1987 TOYOTA SOARER 203.7 KW
5th 1990 FORD COSWORTH 196.8 KW
6th 1988 C33 LAUREL 172.6 KW
7th 1988 RX7 SERIES 4 13B TURBO 170.5 KW
8th 1991 NISSAN LARGO VAN (SR20DET) 139.1 KW
9th 2001 HONDA INTEGRA 129.6 KW
10th 2001 LEXUS IS200 (SUPERCHARGED) 127.3 KW
11TH 1993 S13 (CA-18DET) 119.1 KW
JUST FOR FUN TOTAL KW 2322.5
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby deaf_rattle » Mon May 12, 2008 7:32 pm
maxed the dyno at 333kws? :?
nice power for the soarer though, wonder who that was
Postby tsoob » Mon May 12, 2008 7:40 pm
deaf_rattle wrote:maxed the dyno at 333kws? :?
torque maxed out, the thing had a speed cut at 250kph so when he used a lower gear it made way to much torque, tricky reckons it would be over 400 at the wheels,
The soarer is Alex's (postfach) from here, more to come as he has a much bigger turbo and a 46mm tial from us.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby samlloyd » Mon May 12, 2008 8:02 pm
Pics of silvias and cossy?
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
Postby postfach » Mon May 12, 2008 9:33 pm
should have been more though, i'm disappointed with that figure! i wouldn't have thought the difference between rolling road and hub dyno was 30kw, but it seems like i still have another 3psi available before boost cut so maybe i can squeeze a bit more out of the twins yet.
postfach
Postby tsoob » Mon May 12, 2008 9:42 pm
postfach wrote:should have been more though, i'm disappointed with that figure! i wouldn't have thought the difference between rolling road and hub dyno was 30kw, but it seems like i still have another 3psi available before boost cut so maybe i can squeeze a bit more out of the twins yet.
Mate thats a very impresive figure considering your setup dont be discouraged there is heaps more left in your car yet.
Nick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby bluemaumau » Mon May 12, 2008 11:18 pm
your car?
Postby gleem » Mon May 12, 2008 11:22 pm
how much for a 4wd dyno, if you've still got it?
gleem
Postby tsoob » Mon May 12, 2008 11:36 pm
bluemaumau wrote:your car?
tomorrow
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby bluemaumau » Mon May 12, 2008 11:40 pm
didnt a s14 get 220 or something?
Postby 2jayzgte » Tue May 13, 2008 8:54 am
Ohh yes there is certainly a big difference between Hub and Rollling road the last time I was on the 2 I got 323 KW at 1.2 bar on the Hub and 280 on the Rolling Road so there is quite a big difference I reckon the Hub is more related to a flywheel figure as I no for Damn sure the factory CT 12s will not move enough air to give me 323 RWKW that would be about 350 plus KW at the flywheel nah I don't think so some how.
2jayzgte
Postby Lith » Tue May 13, 2008 10:27 am
The rolling road vs hub thing is quite interesting, at the dyno the Toyspeed dyno day in Palmy was run on I did 262kw @ wheels and a guy from here (can't remember his name off hand) did 157kw @ wheels with his EP82. We ran on a hub dyno a few weeks later with absolutely no changes and I ran 280kw @ wheels while he ran 153kw @ wheels.
He lost 3kw going to the hub dyno and I gained 18kw, go figure :? Maybe the higher power cars extra loss is due to some tire slip?
2007 Mazdaspeed Axela
Lith
Postby loose_unit » Tue May 13, 2008 11:19 am
Think i figured that out out actually Dan. About a week after that 2nd dyno I found about 3 exhaust leaks between the head and the turbo. Got a couple flanges milled and welded a crack up and I instantly gained 3mph back in my trap speeds. Will have to have another go i guess.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby IH8TEC » Tue May 13, 2008 1:04 pm
use one dyno so you can compare mods/gains etc, and put figures down on the track.
Postby YeMs » Tue May 13, 2008 1:20 pm
Lith wrote:He lost 3kw going to the hub dyno and I gained 18kw, go figure :? Maybe the higher power cars extra loss is due to some tire slip?
thats definately a possibility. wen my car was running 400kw, it f**d the tyres completely from wheel spin. had 200L ballast water and 2 mates in the boot to keep it down.
*yems wants a hub dyno run.. :twisted: *
Your local Hybrid Elite tech
YeMs
Postby Lith » Tue May 13, 2008 1:27 pm
Ahhh ok that could explain that :) May indeed have to try again then, though having said that - mine has actually got some nasty leaks too - its what the mysterious squeel was on the dyno. Exhaust manifold was cracked, and has been getting worse.
Lith
Postby loose_unit » Tue May 13, 2008 5:21 pm
I can imagine how bad that would be on a rolling road, we had enough problem trying to stop mine from wheel spinning past around 135kw. We ended up getting 2 guys to sit on the front guards in the end which seemed to work.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby IH8TEC » Tue May 13, 2008 5:26 pm
doesn't matter if it's rolling road, strap it down properly. kent tunes nyle buckleys corona with over 600rwkw on a rolling road. many people to the same.
most of the time if it's spinning on the dyno you can see it on the plot. it's not like you guys have sh1t tonnes of power compared some guys that do, and they never have problems.
yeah tires get warm on rolling roads, my semis got rather hot, he said if he knew they were semi's he would have taken bit longer between runs, road tires are fine
