Gull force 10
Gull force 10
Postby method » Fri May 23, 2008 7:02 pm
Dont think this has been discussed too well, just its bad for older cars due to being corrosive etc.
Thinking of chucking a tank into my turbo 4age ke30.
I have heard it has a higher octane rating than 98, hence being more resistant to knock.
Thats exactly what im after, think im on the verge of getting knock but dont want to have to pull timing as that effects the low rpm performance.
Is it true that it has a higher octane rating than 98?
I know gull use a different system to other petrol stations.. thats all i know
PICS UPDATED DAILY
method
Postby rollaholic » Fri May 23, 2008 7:05 pm
they have some info about it at the pump, could always go have a nosy. i read it once but cant remember what it said for the life of me.
Postby Bling » Fri May 23, 2008 7:05 pm
is this like 10% ethol or whatever? (no gull down here)
Get less mileage don't you? much like running LPG which has a higher octane rating than petrol but you need to use more LPG to get the same power etc
Postby method » Fri May 23, 2008 7:08 pm
BZG|Bling wrote:is this like 10% ethol or whatever? (no gull down here)
The ecu wouldn't know to compensate though would it?
PICS UPDATED DAILY
method
Postby Sideros » Fri May 23, 2008 7:09 pm
The writing on the pump says that it is up to 98 octane fuel - nothing about being "98 octane and higher"
Sideros
Signwriter
Postby fuel » Sat May 24, 2008 12:12 am
it has a higher octane rating so it's less prone to knock, but it has less energy so you'll need to burn more to get the same results.
I've started running it in my daily driver V6 Galant, and I haven't noticed any rough running, around town economy seems to be the same (ie, sh*t), but open road is just as good maybe better than before - I got just over 700kms out of a 54L tank from Hamilton to Whangarei and back with a bit of driving around Auckland and Whangarei.
Aparently the first few tanks it may run rough, as the ethanol absorbs the moisture in the tank and generally picks up debris at the same time. After a few tanks it should come right though. Older fuel systems generally have seals which may not hold up to the ethanol blend, so that's another issue.
LOUD NOISES!!!
fuel
Postby Adamal » Sat May 24, 2008 12:29 am
They do state to have 'anti-corrosive' additivies in it though.
Postby method » Sat May 24, 2008 12:50 am
Mite try chucking it in, hope i dont get poor performance! Ill just reset the ECU and go for a mean drive!
PICS UPDATED DAILY
method
Postby method » Sun May 25, 2008 11:10 pm
Well, seems alright. Cant say if there is any difference between it and 98 from mobil. Car runs smooth and revs nicely.
Mobils 98 claim minimum RON of 97.5, gull claim 98 RON minimum.
PICS UPDATED DAILY
method
Postby Adamal » Sun May 25, 2008 11:42 pm
Yea, I doubt you'd notice any difference. Theres no extra power in a fuel that has a higher octane rating, just an ability to resist autoignition, meaning you can advance the timing some more, which results in more power (to a degree).
Its cheaper than Mobil 98 though eh?
Postby fuel » Mon May 26, 2008 12:04 am
yeah but because ethanol fuel doesn't contain the same amount of energy you actually use a bit more of it to produce the same power as normal fuel.
LOUD NOISES!!!
fuel
Postby grantourismo » Wed May 28, 2008 2:00 pm
using it on my 96 corona nz model for two month all good
grantourismo
Postby samlloyd » Wed May 28, 2008 5:54 pm
Not so good on a RMZ450, clogged some valve in the carb which made it ran like a dog, with carb pulled apart, there was a buildup which stopped a valve working in the carb. So maybe not so good for high performance mx bikes
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
Postby barryogen » Wed May 28, 2008 6:28 pm
everything I have read says it's no good for carb'd engines...
barryogen
2ZZ Guru in training
Postby AE82 FXGT » Wed May 28, 2008 6:52 pm
You have to change your fuel filter after using it for a bit to, apparently the fuel picks up any water etc in your tank.
AE82 FXGT
Postby Adamal » Thu May 29, 2008 11:31 pm
Usually get about 400kms out of a tank in the SW (thin-ass) and by the looks of things, I'm set to get 500kms out of a tank using Force 10.
No change in driving style (IE. giving it the beans most places (but not exceeding speed limits)).
Postby grantourismo » Sat May 31, 2008 2:18 am
grantourismo
Postby ROBODISCO_20v » Wed Jun 04, 2008 11:28 am
What toyota say about it...
http://content.toyota.co.nz/toyota/_cam ... oyota.html
I put 1/4 of a tank in my Altezza. Ran fine, not sure I should have after reading this though.
8. Does the use of corrosion inhibitor in Gull Petroleum's E10 fuel mean I can use it in my Used Import Toyota?
While we understand that Gull Petroleum's E10 fuel does contain corrosion inhibitor; its suitability has not been tested on our vehicles. Therefore our recommendation remains that E10 fuel is not suitable for use in used imported vehicles – refer to the above chart.
ROBODISCO_20v
Postby cat007 » Wed Jun 04, 2008 11:37 am
Does anyone remember that top gear episode where they made diesel then they raced a diesel BMW round a 24 hour race?
Their fuel pump leaked because their home brand fuel had too much ethanol in it and it was eating the rubber seals of the pump.
I'm worried Force 10 will do the same, causing an injector to leak spraying fuel everywhere.....
Postby barryogen » Wed Jun 04, 2008 1:05 pm
ROBODISCO_20v wrote:What toyota say about it...
http://content.toyota.co.nz/toyota/_cam ... oyota.html]
That's a very odd bit of propaganda.
Last time it surfaced I contacted them and asked for the part numbers of the NZ new Corolla GT fuel system, and the part numbers for the RunX fuel system, and they confirmed that they were the same.
I asked them to confirm if the NZ edition got a different tune to the Jap sold ones, they said they don't get a different tune.
So no difference between the two cars fuel system wise, and yet they say no to using it in the import... but the NZ new one is fine.(also they said that their signature class ones are fine too).
It just smacks of a lie.
And just to top it off... point 14 and 15 contradict each other.
If it ever shows up down south, I'll probably use it.
barryogen
