Blacktop motor in AE82, speedo drive question?
Postby Maxwedge » Mon May 26, 2008 6:44 pm
How do you get around not using a electric speedo drive on a blacktop 20v gearbox without it affecting the ECU programming
1- graft in a AE111 speedo?
2- Link ECU?
Maxwedge
Postby xsspeed » Mon May 26, 2008 7:08 pm
from what i understand theres some sort of adaoter from electric to mechanical but i havent crossed this bridge yet
Postby Zak » Mon May 26, 2008 8:14 pm
You get the speed signal from the back of the cluster.
Zak
Postby slighty_sykotic » Mon May 26, 2008 8:38 pm
Zak wrote:You get the speed signal from the back of the cluster.
He wants a mech speedo but the sounds of it, but on a blacktop ecu you NEED to have speed sensor info going to the ecu
slighty_sykotic
Postby Distrb » Mon May 26, 2008 9:04 pm
I never did when i had my blacktop running off the factory ecu in my ae82 fx
I just put a mechanical speedo drive into the gearbox, and it using the speedo cable and factory ae82 dash
Distrb
Regular Poster
Postby slighty_sykotic » Mon May 26, 2008 10:29 pm
It affects the blacktop ecu. ALOT.
Unless you mean that you get the speed signal for the blacktop ecu from the dash!.
Thats the answer, I forgot...
Mech speedo sender in gearbox, speed signal from back for mech dash to the blacktop ecu
slighty_sykotic
Postby Distrb » Tue May 27, 2008 12:50 pm
slighty_sykotic wrote:It affects the blacktop ecu. ALOT.
yeah i figured it was a given that you have to take it from dash if you use mech speedo drive, but obviously not :oops:
Distrb
Regular Poster
Postby xsspeed » Tue May 27, 2008 12:59 pm
so whats the deal with s/top? same principle or does the ecu not require it so much?
Postby 85AW20v » Tue May 27, 2008 2:01 pm
I had to do the same when I fitted the S/T to my AW. Picked up about 1000rpm once I'd done it.
See ya
Simon
85 MR2 20v
85AW20v
