4age ROD question
4age ROD question
Postby lucasthefallen » Fri May 30, 2008 6:13 pm
ok, im currently rebuilding a 4agze 16v ( afm model from a aw11 ). i've got the thing apart, and just having a quick look at the rods, they seem to be quite beefy. i have some silvertop 20v ones, but i havent compared side to side yet. are they any difference's? is it worth swapping the silvertop ones in? will only be running 14psi via supercharger ( pulley kit etc )
any info appreciated.
Need Service or Repair work done? send me a PM
lucasthefallen
Postby Zak » Fri May 30, 2008 7:23 pm
The silver top ones are smaller, but I'm not sure what the strength differences would be.
Both are fine for fairly good power, so I wouldn't worry about it, just use the better condition ones.
Zak
Postby pc » Fri May 30, 2008 11:00 pm
Everything you need to know about 4age rods.
http://forums.toyspeed.org.nz/viewtopic.php?t=58213
Blacktop rods have an unusually high failure rate.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby ChaosAD » Sat May 31, 2008 12:02 pm
the late model gze's run silvertop rods so should be fine
ChaosAD
