help me get my 4agte runing!!
Postby themaleman » Sat May 31, 2008 3:24 pm
the engine as a 4agze.
ok i only have a few 'little' things to hook up now,
the first thing is where do i join this up 2? is it the fuel pres reg??
[img][img]http://img220.imageshack.us/img220/5128/image000dv8.th.jpg[/img]
the next is this thing which is located at the back right of the engine bay (looking at the engine from the front) dose it just need a vacume line on there??
[/img]Image
and lastly theres this thing, i think i was told i dont need it conected at all, but its there so i might as well hook it up. there are 3 hoses coming off of it, from memory 2 of them went to the tb, but im using a 16v 4age intake now and i cant workout where they are to be connected
[img][img]http://img61.imageshack.us/img61/2136/image002pb8.th.jpg[/img]
any help would be greatly apreciated as after these are hooked up (or removed) my car should be finally running![/img]
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby ezy10s » Sat May 31, 2008 3:28 pm
Yup first one is the fuel pressure regulaotr all right- vacuum line to inlet manifold.
second one is the charcoal cannister for emissions/crap. can leave disconnected or if you want run a vacuum line to the inlet also
i have no idea on the third one - anyone else?
Member #244
Gone fishing until further notice
ezy10s
Postby tsoob » Sat May 31, 2008 3:29 pm
they are vac lines dude they need to g to the manifold some where. the little thing is bulshit get rid of it if you can
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby themaleman » Sat May 31, 2008 3:35 pm
ok so i run a vac line to the fuel pres reg.
vac line to the 'charcoal canister'
correct??
and what little thing is bullshit?
thanks for the quick responce guyes!!
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Lloyd » Sat May 31, 2008 3:51 pm
Last one looks like idle up for P/S or A/C
Postby themaleman » Sat May 31, 2008 4:05 pm
these are the 3 lines, 2 are fat, i is small
[img][img]http://img61.imageshack.us/img61/3811/linesxc3.th.jpg[/img]
these are the 2 unocupied pipes on the tb
[/img]Image
since thers only 1 big pipe on the tb dose this mean that its not compatible?
if i dont need it ill remove it completly
4agte ae92 Levin
a15 powered sj410
themaleman
Postby themaleman » Mon Jun 02, 2008 6:59 pm
up
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Paulio » Tue Jun 03, 2008 10:39 am
dont worry about piping out of the TB/plenum, most of that shit isnt needed.
so you have 3 left? where do they come from?
Paulio
Postby tsoob » Tue Jun 03, 2008 3:39 pm
dude we can get it running but need to see the car can you drag it here?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby themaleman » Tue Jun 03, 2008 6:08 pm
read up, those 3 pipes ar cuming off the thing which i refured to in my initial question
tsoob, thers not much point in me taking it to your shop, as i will hopfully get all the answers i need right here. cheers anyway tho
4agte ae92 Levin
a15 powered sj410
themaleman
Postby escortman » Tue Jun 03, 2008 8:31 pm
the big can be blocked
viewtopic.php?t=66648&highlight=throttle+body+4age
have a look at that pic
4x4 toyota blizzard offroader
escortman
Postby themaleman » Thu Jun 05, 2008 3:32 pm
someone must know!!!!
4agte ae92 Levin
a15 powered sj410
themaleman
Postby escortman » Thu Jun 05, 2008 8:15 pm
what do u need to know now
escortman
Postby themaleman » Fri Jun 06, 2008 8:19 pm
ok i think what im trying to hook up is the 'egr-vm' highlightet in blue.
as you can see, there are two pipes leading to it coming out of the inlet manifold, highlighted in red.
i am now using a 16v4age inlet manifold, which only has one pipe resembling the pipes on the 4agze inlet manifold.
my question is..
do the 'letters' on the digram highlighted in red mean anything?
if they dont i assume i can simply T the two pipes comeing off the 'egr-vm' into the one pipe coming out of my 4age inlet mainefold
correct??
4agte ae92 Levin
a15 powered sj410
themaleman
Postby escortman » Fri Jun 06, 2008 9:10 pm
y do u need it, off my car i only have bov fuel reg boost gauge
escortman
Postby themaleman » Fri Jun 06, 2008 9:17 pm
i dont know if i need it, no one has send ' ohh just dont use it'. its there and must do something? it also has wires hooked up to it and a vsv
4agte ae92 Levin
a15 powered sj410
themaleman
Postby escortman » Fri Jun 06, 2008 10:03 pm
yeh i cut all them things
escortman
Postby rollaholic » Fri Jun 06, 2008 10:52 pm
dont bother, its emissions control stuff.
i didnt realise gzes had EGR actually
Postby themaleman » Fri Jun 06, 2008 11:11 pm
sweet, cheers for that
4agte ae92 Levin
a15 powered sj410
themaleman
Postby matt dunn » Fri Jun 06, 2008 11:54 pm
rollaholic wrote:dont bother, its emissions control stuff.
maybe in usa and canada they do,
but none of the ones i have seen in NZ have had EGR on them..
