Dell'Orto wrote:105db at idle is actually not that loud, we have a customer who recently got his RX2 back on the road. It was sitting across the road at pit stop idling away nicely, definately not what I'd call annoyingly loud and it was apparently still 105dbNow its been choked back to 95, you can barely hear the thing idling.
not_paul_from_waiheke wrote:i just dont know what to do, change mufflers every time it needs a wof?
Mr.Phreak wrote:Do they still test V8's at a lower RPM?? Cos I'm $&#$% if they run the Soarer up to 4500
barryogen wrote:If it has vvt even if it's an 8, they test to 4500RPM or there abouts, not sure on the specifics though, havent looked at 8s.
Mr.Phreak wrote:barryogen wrote:If it has vvt even if it's an 8, they test to 4500RPM or there abouts, not sure on the specifics though, havent looked at 8s.
Where'd you get that from??
They only seem to care about VVT in engines with 5 or less cylinders, which they go to 4800.
not_paul_from_waiheke wrote:Would the difference between a test at 3000rpm and 4500rpm produce significantly louder results?
B1NZ wrote:they should all be choked back to that, Yucky noises![]()
