BlakeNZ wrote:hi avenish, i have had my car's 02 wire extended (for my twin dump pipes). any auto electrician can do it. it is shielded cable.what turbo are you putting on?
NZ_AE86 wrote:It is quite clear that Matt is the only person who knows how an Oxy sensor works!
CRIMP ONLY as a lot of Oxy sensors breath through the cable - between the insulation and the wire.
sergei wrote:1) soldering is a "high" resistance joint
2) voltage of the sensor is very low
neither of those are true.
matt dunn wrote:Oxy sensors work on such small voltage that the resistance in a solder joint, (and there is) can affect the accuracy.
In reality probably bugger all.
