extending oxygen sensor wiring
BlakeNZ wrote:hi avenish, i have had my car's 02 wire extended (for my twin dump pipes). any auto electrician can do it. it is shielded cable.what turbo are you putting on?
im putting on a dsr 430 which is suppose to be a close spec to gt30 40
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
jza80 supra = 11.7
ok everything is in now but i cannot get the boost over 8psi i wana put it to around 11-12psi lookin at the turbo the actuator is closed when car is off so that seems to work but dunno why i cannot raise the boost more an also the bad thing is my oil return has a bit of a rise in it an then it goes down will this affect things cheers
220.1 rwkw
jza80 supra = 11.7
jza80 supra = 11.7
NZ_AE86 wrote:It is quite clear that Matt is the only person who knows how an Oxy sensor works!
CRIMP ONLY as a lot of Oxy sensors breath through the cable - between the insulation and the wire.
right...
The debate was more about the soldering vs crimp.
What set me off is that Matt stated that
1) soldering is a "high" resistance joint
2) voltage of the sensor is very low
neither of those are true.
I also stated that original poster could extend the wires and solder them together after the plug (loom side), without touching the original sensor wirings. Shielding is preferred, but not necessary as last ~30cm of the wiring is unshielded anyway.
Whether they breathe or what other reason why manufacturers recommend crimping is completely other matter.
sergei wrote:1) soldering is a "high" resistance joint
what matt said was
matt dunn wrote:Oxy sensors work on such small voltage that the resistance in a solder joint, (and there is) can affect the accuracy.
In reality probably bugger all.
Dont see the word high in there,
and what someone calls low voltgae is always going to be up for debate.
the reason for not soldering is the wire is nichrome and not coper and it can't be soldered with standerd soldering equipment (stuck togther /= soldered btw).
in addition, even if you used the correct soldering equipment i beleiev the joint can develop a significant voltage across it when the wires on the sensor side get hot. something to do with being two different metals nichrome and copper.
the crimp terminals with the 2 sets of tangs that are folded in are really good.
the crush type ones with the red/blue/yellow insulators are not as good but acceptable if crimped with a proper pair of ratcheting pliers.
meh.....
What a funny thread.
The only reason crimp connections are used is for time and money.
If you're doing the job for someone else, use crimps.
If you're doing the job for yourself, solder it.
The best way to extend it is to leave the sensor and loom both standard, get a plug and socket from a wreck and make an extension piece. That way when it $$% out faultfinding is easier.
Steve
Steve
Computers make you go mad.
An Oxygen sensor needs to 'sample' air from outside the exhaust. Some do this through one or more sample holes in the sensor body but others sample air through the wires - between the wire and the insulation.
When you buy a new Oxygen sensor the warning to only crimp is not just to waste ink - they do not want their product to give problems due to installation faults.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
1986 Levin GT
