1990 Celica GT4 st185 doesnt boost
Postby dvmv_kim » Fri Jun 20, 2008 4:06 pm
last night i was driving and i was going up a hill so i plant my foot on the accelerator then it went bang after i let my foot off and now on the aftermarket boost gauge it doesnt go over 0 its always under 0 psi the turbo has no play in the shaft and spins nicely not blowing any white smoke the problem is, its just not boosting and its really slow and the idle is fine and the turbo doesnt have any knocking sounds like blown turbo can anyone please help me? thanks
dvmv_kim
Postby ~SlideWays~ » Fri Jun 20, 2008 4:12 pm
Boost leak possibly. Check all joiners and vacuum hoses.
~SlideWays~
Postby dvmv_kim » Fri Jun 20, 2008 4:16 pm
yeah ive checked it out i even got a guy from pitstop to have a look for me he think it might be like a fault or boost source thingy, im sure its not a boost leak cause you cant hear the turbo spoil up anymore cause the turbo should be winding up like usual so i dont really know.
dvmv_kim
Postby Dell'Orto » Fri Jun 20, 2008 6:22 pm
Does the factory gauge still move?
Postby Prymal » Fri Jun 20, 2008 11:35 pm
sounds like your boost source taps gone fuzz .. that blows off with a bang , then 0 boost .. used to happen regulalrly ith crappy hose for an equally crappy guage i had in my old St185
bought autometer , never had an issue ..
Prymal
Postby dvmv_kim » Sat Jun 21, 2008 3:06 am
no the factory gauge doesnt work since i disconnect it to run over 12psi and "classique71" you think the boost source taps faulty or dead? and with the autometer is that the boost gauge or you talking about a autometer boost source taps? sorry for asking dumb questions just need to make sure
dvmv_kim
Postby avinesh » Sat Jun 21, 2008 4:35 am
dvmv_kim wrote:no the factory gauge doesnt work since i disconnect it to run over 12psi and "classique71" you think the boost source taps faulty or dead? and with the autometer is that the boost gauge or you talking about a autometer boost source taps? sorry for asking dumb questions just need to make sure
i think you have a broken exhaust turbin wheel same happened with a mate of mine no smoke no noise an no boost
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby dvmv_kim » Sat Jun 21, 2008 11:32 am
did he repair it or bought a new turbo? i thought i might of snapped the shaft
dvmv_kim
Postby dvmv_kim » Sat Jun 21, 2008 11:41 am
i usually see on trade me people put like garret internals on a ct26 so does that mean i can get any turbo and put all the inside bits into the ct26?
dvmv_kim
Postby Adydas » Sat Jun 21, 2008 11:47 am
not quite, somone else will need to do it for you.. like a pro rebuilder.. so start saving some $$$
Adydas
Postby Dell'Orto » Sat Jun 21, 2008 1:20 pm
If you've blown the exhaust wheel off, the car will sound likea tractor and be gutless as hell.
No you can't put any old Garrett turbo internals into yours, its usually a T04 compressor wheel they use as well as giving your turbine wheel a backcut to let it flow more up top.
Postby avinesh » Sat Jun 21, 2008 1:54 pm
Dell'Orto wrote:If you've blown the exhaust wheel off, the car will sound likea tractor and be gutless as hell.
wont always sound like a tractor i bought a soarer with the exhaust wheel broken off an it sounded mint on idle an even when moving but no boost
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Dell'Orto » Sat Jun 21, 2008 4:00 pm
Thats because a Soarer is a 6 cylinder, when I blew the turbo on my MR2 it definately sounded even more like a tractor than usual.
Postby avinesh » Sat Jun 21, 2008 9:42 pm
Dell'Orto wrote:Thats because a Soarer is a 6 cylinder, when I blew the turbo on my MR2 it definately sounded even more like a tractor than usual.
yea well i dunno if cylinders would affect that but im just givin him some ideas chances are it may well be the exhaust wheel
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby dvmv_kim » Sun Jun 22, 2008 6:24 am
oh okay so how much would it cost for a new turbo for the st185 or am i better off buying a 2nd hand ct26?
dvmv_kim
Postby Adydas » Sun Jun 22, 2008 10:59 am
apparantly $300 compleate with wa/\/k external..
http://www.trademe.co.nz/Trade-Me-Motor ... 941162.htm
but for 469 apparantly you can get this for it..
http://www.trademe.co.nz/Trade-Me-Motor ... 890241.htm
Just depends what you wanna spend and what you wanna do..
a *new* ct26 will cost over $1000 i think youll find.. im pritty sure somone priced one from toyota at some stage around $1550.. +gst
Adydas
Postby Dell'Orto » Sun Jun 22, 2008 1:12 pm
avinesh wrote:yea well i dunno if cylinders would affect that but im just givin him some ideas chances are it may well be the exhaust wheel
Funnily enough, yes the amount of cylinders does affect the noise a car makes :lol:
Maybe chat to Alltech about having your turbo rebuilt and highflowed...cost me $850 a couple of years back to have a CT26 done by MSE.
Postby avinesh » Sun Jun 22, 2008 2:42 pm
lol yea the number of cylinders do change the sound a car makes but with a broken turbo how does a 4 cylinder sound like a tractor an a six doesnt make any weird sounds just didnt understand that part
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Boosted_162 » Sun Jun 22, 2008 2:48 pm
3SGTEs sound like tractors regardless :lol:
Postby dvmv_kim » Sun Jun 22, 2008 3:48 pm
okay thanks guys, but with classique71 he said the boost tap might have gone fuzzy is he talking about the boost controller or the boost source near the firewall? i took the air filter pipe of and played with the turbo fan it has no play??
dvmv_kim
