cheap-ish and good (if that exists)
cedwards wrote:mine did all sorts of things on the way out, are you sure the tacho is giving correct readings? My fault initially was very intermittent and the dials would sometimes just freeze in position for a second then would go back to normal or on the piss. Engine check light generally comes on when it is "offline" for a few seconds of driving.
I think in the Auto's it can lead the trans up the garden path creating all sorts of strange gear changes or no change at all being left in first while trying to drive on the motorway etc
