Flunk wrote:High intensity discharge (HID) conversion kits
HID conversion kits (an HID bulb with a high voltage power unit or ‘ballast’ which fits into the original headlamp unit in place of the original bulb with no change to the headlamp lens, reflector or housing) are illegal on any vehicle being used on New Zealand roads.
However, a complete halogen headlamp unit can be replaced with a complete HID headlamp unit provided that the replacement headlamp unit complies with approved standards. If in doubt, get advice from a vehicle lighting retailer you trust.
NZ_AE86 wrote:Flunk wrote:High intensity discharge (HID) conversion kits
Where is that writeup from? I have been asked this by several customers in the last two weeks and the way I read the VIRM I would give them a WOF. But I have heard a lot of people say they are not legal. All I have to go on as a WOF inspector is the VIRM which most of the time means I decide if it should have a WOF as most of it is left up to inspectors opinion!
HRT wrote:Going by the VIRM though most HID swaps aren't legal anyway as the reflectors aren't right so you cant actually focus them. But if they can get a decent pattern from one then from an AVIC point of view you'd probably have to pass it
SUBARUCONVERT wrote:just had this problem at work, had a evo 5 in with a hid kit, i ended up issuing the wof. it worked fine and had a good pattern so i let it go. i dont think plastic lenses would be a problem, most new cars with factory hid have them
AE82 FXGT wrote:
Why are the ballast systems illegal then? I thought it was because of the headlamp itself?
What makes you think the ballast systems are illegal?
method wrote:I've fitted a hid kit into both my cars i used to have.
never had WOF problems. Makes a huge difference to driving at night on the open road too. Can see so much better.
