gepsk8 wrote:thats ur problem u need power on otherside for light to work!
if u put it dash light make sure it look factory(been in car all its life, u may need to pull dash see if theres abs light if not get another dash with abs and fit that)
and no cert required as long as light goes out mechanic not gona give a sh*t.
Infinite wrote:u dont actuley have to cert going to/from abs ive removed abs in many cars. can u handel the power of the silvertop if u don't know howto brake without the help of abs?
Rob wrote:You know you could have got normal 101 suspension with ABS and it would have been a lot cheaper than having to replace the superstrut arms every so often
