Engine removal
Engine removal
Postby TRD_ZERO » Wed Aug 13, 2008 6:58 pm
Time to take the engine out the ae111........... So my quick question is do i take it out the top or drop it out the bottom? Ive got a engine hoist just looking for the easiest way to get it out.
TRD_ZERO
Postby Burning Angel » Wed Aug 13, 2008 7:02 pm
ive never tried dropping one out the bottom but i found it very easy to take out the top.
just detached everything and carefully lifted it tilting the engine side up slightly.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby AceSniper » Wed Aug 13, 2008 7:43 pm
I find 20v's easy to drop out the bottom, just drop subframe, loom, axles, support engine on hoist(have hoist pumped up) undo 3 bolts on end gearbox mount and two studs under the right mount and you can lower it down.
use axle stands to hold the car at there full hight so you can move the engine from under the car
AceSniper
Postby escortman » Wed Aug 13, 2008 10:58 pm
i vote top
4x4 toyota blizzard offroader
escortman
Postby Boosted_162 » Wed Aug 13, 2008 11:01 pm
Most mine have been out the bottom, cos they were 4WD. Did a 4EFTE out the top and found it was much easier then lifting the car off and dragging the motor out. So id say out the top if it will fit :)
Users browsing this forum: Bing [Bot] and 25 guests
