HamzGTT wrote:im doing everything except the seals seeing that the car has only done 94000kms I dont see the point of fixing sumthin that aint broke if it was around the 200000km mark then yes.
HamzGTT wrote:Too many ppl say you get more problems replacing the seals than leaving the original ones in there. I understand where your coming from originally that was my plan to replace everything.
strx7 wrote:If you do the seals in the oil pump, make SURE you full the oil pump up with oil when you put it all back together. I had an ar*e of a time trying to get my oil pump to prime on my rebuild.
