oil leak from the back of engine (supra)
Postby sideways soarer » Mon Aug 25, 2008 9:45 am
hey guys,
i have an ma70 with a 7mgte and i was haing a look under the car in the weekend and noticed quite a bit of oil leaking, it looks like its coming from between the block and the bell housing, and the a little more between the bell housing and the gearbox (gear box is a w58).
engine still has plenty of oil and gear box still shifts smoothly and no funny noises or anything, so im not sure how long it has been doing it for and not sure if its coming from the enginge oil or the gear box oil.
i checked the stock oil pressure gauge (digi dash) and it goes up to 5 bars when started but then drops down to 2 bars and stays there, even under hard acceleration it stays at 2 bars, is that normal? seems abit low to me, i always thought the oil pressure should increase as you accelerate
has anyone else had this problem before? is there a gasket or something in between these parts that may have failed? any ideas from the supra gurus out there would be much apreciated :D
sideways soarer
Postby Jason T » Mon Aug 25, 2008 10:36 am
Rear crank seal...http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=EM&P=87
Easy enough to replace with out removing alloy retainer
Oil presure system is high volume low presure mine runs 2 bars on dig dash up to 5 for a short time hard into it
Factory guage is slow to react and senders crap out
How to check presure http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=LU&P=4
Fixing Toyota's since '87
Jason T
Postby sideways soarer » Wed Aug 27, 2008 9:29 am
ok sorted, should be fairly straight forward to fix that, hopefully i wont rain all weekend so i canget it done. that TSRM is a great resorce :D
decided to change the gearbox fluid tonight i cant see the drain plug but where is the refill plug located and what does it look like? (the pictiures on the tsrm arnt very clear)
just wanted to double check i can refill it with no problems before i drain it. as it my daily driver at the moment 8O
sideways soarer
Postby Jason T » Wed Aug 27, 2008 12:24 pm
Left side of the box at half way mark just in front of reverse light sensor
That bolt is fn tight careful not to round power bar with a jack makes it easy
Take out the stick and fill from there
Check the bushing the stick sits on and at the end of the the stick at the same time
Royal Purple Max-Gear 75W90 is what I put in my W58 buy from http://www.staparts.co.nz/
Jason T
