the fallen303 wrote:will be fine, stock pumps can handle 1 bar boost easy.
avinesh wrote:the fallen303 wrote:will be fine, stock pumps can handle 1 bar boost easy.
what about 16psi.....have seen a lot of supra guys running 16psi, is this safe????
Lith wrote:BlakeNZ wrote:your turbos will run out of flow before your fuel system does..supra pumps are one of the best. up to 300rwkw.
x2, from what I recall they can pump quite happily.
the fallen303 wrote:there is a mod that you can do to make the pump work at 12v all the time, usually they change between high and low voltage, flick to high when foots up it. helps pump last longer, etc.
avinesh wrote:the fallen303 wrote:there is a mod that you can do to make the pump work at 12v all the time, usually they change between high and low voltage, flick to high when foots up it. helps pump last longer, etc.
i know wat you mean but is it necessary???
