4age 20v not starting
Postby deaf_rattle » Sat Sep 06, 2008 7:56 pm
Ok just replaced the water pump and thought i had everything timed up.
car wont start now, at all wont even turn over.
I am pretty sure i had it timed up correctly, but checked it just now and the crank is on -5.
the cam pulleys i had lined up with the notches and the 2 punch type marks on the pulleys.
Would timing cause the car not to turn over? or should i look at something else?
Postby ChaosAD » Sat Sep 06, 2008 8:04 pm
So the starter wont even turn over? does it even click? can you turn the engine over by hand?
ChaosAD
Postby evil_si » Sat Sep 06, 2008 8:38 pm
timing wont stop the car from cranking.
does it click? or try to crank?
check the starter motor wiring is secure. especially the small key signal wire
evil_si
Postby deaf_rattle » Sat Sep 06, 2008 8:53 pm
i get a click, but thats about it. 11.7volts at the rsm and i had my optima connected at one point as well.
Postby ChaosAD » Sat Sep 06, 2008 9:04 pm
11.7 while cranking or key off?
may just need a charge or maybe a bad earth
ChaosAD
Postby ChaosAD » Sat Sep 06, 2008 9:06 pm
The starter has a solenoid wire and a fat wire going straight to the battery, make you didnt leave the fat one off the battery terminal
ChaosAD
Postby deaf_rattle » Sat Sep 06, 2008 9:07 pm
11.7 with key on, fan on but not running. it drops abit when cranking.
Might charge it over night and check earths. but wouldve thought it would start with the optima.
Postby MrOizo » Sat Sep 06, 2008 9:18 pm
havent done something like put the cam pulleys on backwards?
thats if you took them off?
MrOizo
Toyspeed Legend
Postby deaf_rattle » Sat Sep 06, 2008 9:38 pm
cam pulleys stayed on.
i should set the thing on fire! only need it for another 2-3 months
doh!
Postby ChaosAD » Sat Sep 06, 2008 10:13 pm
Dumb question, but did you also line up the crank when you lined up the cams?
Not that it would prevent it from turning over unless the valves were touching the pistons or something. You turned it over by hand and rechecked it aye?
ChaosAD
Postby deaf_rattle » Sat Sep 06, 2008 11:20 pm
yeah, lined up crank and pulleys
tried it twice and then tried to start
although now when cams are at tdc, the crank is at -5. so not sure what happened there.
Postby MrOizo » Sat Sep 06, 2008 11:32 pm
Maybe the starter is a bit sticky?
Would it be worth taking it apart and having a clean on the inside?
You say its clicking but not turning? take it and have a lookie anywyas? try another one if thats possible?
MrOizo
Toyspeed Legend
Postby deaf_rattle » Sat Sep 06, 2008 11:34 pm
yeah, i should
i really cant be arsed with it though lol!
just want to work on the supra.
maybe i should just sell this as is and buy some other hunk of junk to get me to work until i get the company car.
Postby MrOizo » Sat Sep 06, 2008 11:49 pm
mihgt as well! :P
i would offer a hand for tomorrow but i think the day is pretty packed :o
MrOizo
Toyspeed Legend
Postby 85AW20v » Sun Sep 07, 2008 1:58 am
Be careful timing up the 20v. On one of the pulleys - I'm sure its the exhaust - there are two marks and it's easy to get the exhaust wrong. You need to look down the oil filler hole to make sure the inlet is right - there's a dimple that you should be able to see when the crank is at TDC. It lines up with the flat plate that comes halfway across the filler hole. You'll see what I mean when you have a look.
See ya
Simon
85 MR2 20v
85AW20v
Postby rollaholic » Sun Sep 07, 2008 9:24 am
as evil si said timing will not stop it from at least trying to start.
i havent looked at a 20v in forever, but do they have that earth lead with a plug in the middle running from the head to the body by the cambelt covers? and if they do, did you plug it back in / reattach it properly?
Postby evil_si » Sun Sep 07, 2008 1:02 pm
rollaholic wrote:as evil si said timing will not stop it from at least trying to start.
good point. have you got a multi meter? check the earth resistance between the engine and chassis / earth terminal on battery, shouldnt be more than 1-4ohms
tried giving the starter solenoid a tap with a hammer?
if it clicks its got power to it, my guess is high earth resistance or a fu*ked starter motor,
if the earth is good try roll starting it :)
evil_si
Postby matt dunn » Sun Sep 07, 2008 10:44 pm
Simon85MR220v wrote:Be careful timing up the 20v. On one of the pulleys - I'm sure its the exhaust - there are two marks and it's easy to get the exhaust wrong. You need to look down the oil filler hole to make sure the inlet is right - there's a dimple that you should be able to see when the crank is at TDC. It lines up with the flat plate that comes halfway across the filler hole. You'll see what I mean when you have a look.
Actually both the cam wheels have two marks,
one has two dimples and one has a dimple and a line.
They should line up at TDC with two dimples at the top,
and then the other dimple and the line should line up with each other in the centre of the head.
Postby deaf_rattle » Sun Sep 07, 2008 10:48 pm
anyone got pics? to make sure what ive done is right.
Postby matt dunn » Sun Sep 07, 2008 11:00 pm
Try this picture,
