Wheel Question
Wheel Question
Postby TRD_ZERO » Sun Sep 07, 2008 12:01 pm
Im looking at getting some wheels at some stage but just doing a little research before hand. Im wanting to know about these wheels as you can see by the pic the top one where it is bolted to the hub is alot more recessed than the one on the bottom. Why is that? I like the ones at the top but the ones at the bottom look completly different with the center bit sittling out alot further. Has it got to do with offset?
Wheels size? As i remember it was a similar issue with those dtm gt30's when they were in 17s the face was rather flat but in 18's the center is recessed.
Id be wanting to get a set of the ones in the pic at the top for my ae111 or would something like offset or whatever else make me have to get the ones at the bottom?
Thanks all input appreciated.
TRD_ZERO
Postby Boosted_162 » Sun Sep 07, 2008 12:17 pm
Its to do with offset and width. Take a look at the wheels on my Lexus, the fronts are 17x8, with a +30ish offset? (assuming here) and the rears are 17x9 with a +15 offset. They are the same wheel, just look quite different.
Postby d1 mule » Sun Sep 07, 2008 12:26 pm
offset explained
d1 mule
Postby TRD_ZERO » Sun Sep 07, 2008 12:38 pm
Oh ok sot the picture in the top has a negative offset and the one in the bottom has a positive one then? Im guessing ae111 wont be able to fit a negative type one and id have to get positive ones right? They look like two completly different mags just because of the offset.
What is the maximun negative offset a ae111 can run so i could get that recessed look.
TRD_ZERO
Postby Boosted_162 » Sun Sep 07, 2008 12:44 pm
TRD_ZERO wrote:Oh ok sot the picture in the top has a negative offset and the one in the bottom has a positive one then? Im guessing ae111 wont be able to fit a negative type one and id have to get positive ones right? They look like two completly different mags just because of the offset.
You wont be able to run negative offset wheels on an AE111, they will stick out a lot! Standard offset is around +35 - +40 (thats a measurement in millimetres - a +20 wheel's hub sits 15mm closer to the inside lip than a +35 wheels hub)
The recessed ones dont have to be negative offset, mine are +15.
Oh, and check out soopachargen's wagon, afaik he has the same wheels as me (the rear ones) on his 101? wagon.
Postby TRD_ZERO » Sun Sep 07, 2008 1:15 pm
Oh ok so i can get that recessed look for my ae111 then.
TRD_ZERO
Postby Boosted_162 » Sun Sep 07, 2008 1:53 pm
Thats soopachargen's wagon. Same wheels as me, just different colour, and i run 8's on the front.
Postby TRD_ZERO » Sun Sep 07, 2008 7:11 pm
Damit they look good even abit of stretched tyre there. Are they dot com wheels?
TRD_ZERO
Postby Boosted_162 » Sun Sep 07, 2008 7:13 pm
TRD_ZERO wrote:Damit they look good even abit of stretched tyre there. Are they dot com wheels?
Yep. I got mine from Nick @ Magwarehouse North Shore. His tyres are very stretched, i got 215s and 225s on mine.
Postby soopachargen » Sun Sep 07, 2008 7:26 pm
Thats me!!! im e-famous!!
not all 205s will stretch onto a 9 inch rim easily, i got lucky and the ones i already had went on without even needing a gusher, it rides like ass and i've never even chanced taking them through a warrent but it gives the euro/vw look i was going for with silly stretch
When in doubt, down and out.
soopachargen
Postby Bling » Sun Sep 07, 2008 7:30 pm
not sure why you don't think negative wheels will work Boosted_162 :lol:
I mean check this out.... :wink: :lol:
care of Snoozin:
Postby soopachargen » Sun Sep 07, 2008 7:47 pm
here's another photo after i gave it some more camber to tuck them more, it shows the concave of the wheels well
soopachargen
Postby Boosted_162 » Sun Sep 07, 2008 7:49 pm
BZG|Bling wrote:not sure why you don't think negative wheels will work Boosted_162 :lol:
care of Snoozin:
Ok. Ill admit it does work. And thats the best looking ITR ive ever seen with those wheels :D, but its not exactly legal to have them sticking out so far :lol: :lol:
Postby Bling » Sun Sep 07, 2008 8:11 pm
yeah the tyres need to be slightly thinner. As long as the tread itself is within the limits off the guard the rim can stick out past afaik
Postby soopachargen » Sun Sep 07, 2008 8:16 pm
it also says that the tyre must be of a size suitable to the width of the wheel as stated in the tyre manufacturers recomendation or something along those lines
soopachargen
Postby Bling » Sun Sep 07, 2008 8:25 pm
Probably says the wheel itself should be of recommended size by the manufacturer too, but who listens to every single part of the rule :lol:
Within 5% of OEM overall diameter too... or something like that.
Was only pointing out the tread point, as thats what a WOF inspector would first notice
Postby d1 mule » Sun Sep 07, 2008 9:04 pm
that integra looks sooooo stupid with those on it!!!!
d1 mule
Users browsing this forum: Bing [Bot] and 29 guests
