by samlloyd » Sun Sep 14, 2008 5:42 pm
Vacuum doesnt appear to be out of the ordinary.
I dont think a hose has popped off as this would cause an irratic idle.
Turbo dieing could be a possibility, but the shaft still feels ok.
Wastegate actuator feels fine, and can only open once there is enough pressure there.
I feel there is a leak only when under boost. It sounds kind of like an external, but with air more then exhaust. I will check all the exhaust flanges aswell. But for it only to be doing it when under high boost.
(you can only hear it leak at about .9 Bar)
Karl Pilkington On seals - "Its between a fish and a dog."
