Lowering Toyota ALLEX
Postby BZR4AGE » Mon Sep 15, 2008 2:04 pm
Tyrepower @ harris Road is open during saturday till 1pm.
I've got my coilover fitted $100 perside, thats including laser alignment, camber adjustments and height adjustments.
I imagine they will change lower just fitting springs.
BZR4AGE
Postby Timoz » Tue Sep 16, 2008 1:28 pm
$400 bucks installed incl all those alignments is a decent price. i would suggest if u are a daily driver just save more money and get good shock and spring set up. low and firm ride but not to harsh on bumps
Timoz
Postby GTCRSHR » Tue Sep 16, 2008 1:54 pm
how much difference would upgrading the shocks at the same time as installing springs make ? does toyota do a bolt in kit for the allex ?
cheers !
Nothing to see here ...
GTCRSHR
Postby Heylin » Tue Sep 16, 2008 2:26 pm
hey guys, thanks for the reply, yeah the trd springs have gone up about $100 since i asked you about them, i guess thats the price of steel etc,
No that would be the price of Toyota :) always putting prices up. Last rise they had was accross the board and was pretty big.
You can usually get Eibach Pro Street springs for cheaper (same as TRD, Eibach make them under license for TRD).
As for sacking the shit out of cars to make them look nice, thats all good if youre into that, but youre going to lose comfort and drivability + we arent talking about a performance car here so you wont get much performance benefit either.
I paid $245 to get 4 shocks + 4 springs installed and wheel alignment on the MR2. (Top Town Tyres here in Hamilton.
Did you look at some after market wheels, window tinting and a mild lower (20-30mm) perhaps to make it look nice ?
Heylin
Heylin
Postby GTCRSHR » Tue Sep 16, 2008 3:01 pm
hey thanks for the reply, interesting to know about Eibach springs will have a look into them
got new wheels and tints already, ill get that picture so you guys can see what i mean about the gap, maybe im not thinking about it right, maybe 35mm would be fine, i guess the cars that are completely sacked will probably handle like crap anyways which is what i am trying to avoid i want to go for a bit of each,
GTCRSHR
Postby Heylin » Tue Sep 16, 2008 3:49 pm
Sounds like youve got it looking pretty nice already.
I would reccomend TRD \ Eibach Springs (Try ebay while the dollar is ok). And mabey throw in a front strut brace to increase cornering stability.
35mm is plenty low, I lowered my MR2 30mm and it struggles on some driveways. + if you go over that you have the hassle of certing for lower suspension and youll get pulled over for random checks all the time.
Heylin
Heylin
Postby Mr Revhead » Tue Sep 16, 2008 7:00 pm
Eibach springs will be good
however the only place i have ever heard mention of eibach making TRDs srings is the internet. I suspect thats a rumour that started off in the US
If you can find some eibach in nz for a good price they would be worth while, failing that i think tein would be the best option, they tend have fairly similar rates as TRD. in fact other than being green they look exactly like the TRD ones!
wouldnt surprise me if they were made in the same foundry
Postby GTCRSHR » Wed Sep 17, 2008 11:48 am
right this is what i want to get rid of
the more i look at it its not too bad, just wouldlike something that was sitting more around the edge of the tyre but getting bigger wheels could help that, i just picked them up to get rid of the hub caps till i find a style i like and that suits the car,
GTCRSHR
Postby barryogen » Wed Sep 17, 2008 12:11 pm
are they the right size wheels/profile?
barryogen
2ZZ Guru in training
Postby GTCRSHR » Wed Sep 17, 2008 12:26 pm
:?: wheels are 15 x 6.5 and tyres are 195 55 15's
GTCRSHR
Postby barryogen » Wed Sep 17, 2008 2:09 pm
close enough to stock as to make no difference.
it just seems like there is a large gap there.
barryogen
Postby GTCRSHR » Wed Sep 17, 2008 2:16 pm
barryogen wrote:close enough to stock as to make no difference.
thats why i thought there was something going wrong, there was 60's on it before(tyres) and it was no where near that gap same size wheels etc
GTCRSHR
Postby xsspeed » Wed Sep 17, 2008 2:43 pm
Slightly OT but whats the stud pattern and offset, could be interested in buying those off you when you go larger
Postby GTCRSHR » Wed Sep 17, 2008 2:46 pm
4x100, will have to check on the offset, +35 springs to mind but will check for you
GTCRSHR
