ARGHHH! Bits left over
Postby benj » Fri Sep 19, 2008 7:20 pm
Can anyone help me identify this part, which I assume is from my ST205? It was "left over" when the car was put back together!
The numbers are
23080-74030
196170-0240
My search via google and the parts database on toyodiy.com has not yielded anything useful.
Thanks
Benj
1997 JDM ST205 - Busted!
2009 Ford Mondeo Diesel
2000 Audi A4 Quattro 2.4
1981 Landrover Series III Diesel
benj
Postby jondee86 » Fri Sep 19, 2008 7:40 pm
Going by the heatsink, I'd say it was a resistor pack for the
injectors...
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby evil_si » Fri Sep 19, 2008 7:41 pm
im not familar with st205's but it looks like an injector ballast
evil_si
Postby Mr GTZ » Fri Sep 19, 2008 7:44 pm
Toyota calls it a Fuel Pump Register.
Mr GTZ
Postby benj » Fri Sep 19, 2008 9:15 pm
Great, have now found it on the toyodiy.com site.
Any idea where it plugs in? Shockingly noobish question I realise! And is it important as the car seems to be running fine without it.
Benj
benj
Postby benj » Sat Sep 20, 2008 7:43 am
If anyone's interested my research has led me to the following:
The resister is used to vary the output of the fuel pump. The car should not run without the resister in place, it will start and run for about 20 secs then cut out. Funnily enouch exactly what mine was doing before the auto sparky got his hands onit and bypassed the resister, which wasn't installed, so I now have to install the resister and find where he's run the bypass to sort this out.
The bypass will mean that the pump is running flat out all the time hence increasing wear.
Cheers for the help guys.
Benj
benj
Postby fivebob » Sat Sep 20, 2008 2:21 pm
benj wrote:The bypass will mean that the pump is running flat out all the time hence increasing wear.
I don't think there's any need to worry about that. It's quite a common mod to bypass the resistor anyway, and I've never heard of any fuel pumps failing because of it.
Postby rmf55 » Sat Sep 20, 2008 6:40 pm
interesting, i've got one of those hanging off the battery clamp. it was a leftover part when the engine went in and out- noone knew what it was and what it was doing. to be honest i'm still going to have to reread your posts to figure out!
rmf55
Postby matt dunn » Sun Sep 21, 2008 12:24 am
pretty sure the only reason they fit the resistors to the fuel pump circuit is
so that the pump is quiet when the car is idleing at the lights,
just stops the pump noise as it's only running at 1/2 speed.
Bif the resistor in the bin if it's already been bypassed.
Postby benj » Sun Sep 21, 2008 9:16 am
I think I will figure out how they bypassed the resister first, I have a feeling it was a bit of a "rangi-mod" and as such I may have to re do it properly.
I have a whole new weird problem now so I'll post another thread.
Benj
benj
Postby Rob » Sun Sep 21, 2008 9:54 am
Just wondering who the sparky was boss? Some of them are bloody useless!!!!!!
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby benj » Sun Sep 21, 2008 7:06 pm
Unfortunately I have no idea, it was someone who the mechanic who was reinstalling the engine called in when he had problems with keeping it running, I will try to find out without being to confrontational about it as the mechanic has done a pretty damn good job.
Benj
benj
