When changing discs, (i am running ae111 discs on an ae101) does it matter if the centre hole isnt the exact same size? the ae111 disc appears to have a 1mm larger centre bore (resulting in a half mm gap around the centre "spigot").
With the wheel bolted on will this be an issue or should it be fine?
Second question,
My ae92 fxgt brake prop valve looks to have the same brake fittings on it as the one in my ae100 wagon, when converting my rears to discs could i get away with using the fxgt prop valve?
Third question,
is the front suspension knuckle the same between the ae101 and ae92 (has anyone compared them?)
