Brake questions
Brake questions
Postby soopachargen » Wed Sep 24, 2008 9:23 pm
When changing discs, (i am running ae111 discs on an ae101) does it matter if the centre hole isnt the exact same size? the ae111 disc appears to have a 1mm larger centre bore (resulting in a half mm gap around the centre "spigot").
With the wheel bolted on will this be an issue or should it be fine?
Second question,
My ae92 fxgt brake prop valve looks to have the same brake fittings on it as the one in my ae100 wagon, when converting my rears to discs could i get away with using the fxgt prop valve?
Third question,
is the front suspension knuckle the same between the ae101 and ae92 (has anyone compared them?)
When in doubt, down and out.
soopachargen
Postby strx7 » Wed Sep 24, 2008 10:37 pm
really the disc should be spigotted to the hub.
Postby rollaholic » Thu Sep 25, 2008 8:03 am
the Pvalve on your wagon will probably have more bias towards the back than an FXGT one, if it has the same fittings why not use the AE100 one?
Postby BigDon » Thu Sep 25, 2008 9:23 am
It will be an issue, ask Neo. Its not that hard to get the right size disc is it. The superstrut Ae101s have different size holes vs non superstrut 54 vs 55mm but the non superstrut ae101 is the same disc as the non superstrut ae111.
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
Postby tsoob » Thu Sep 25, 2008 9:52 am
yeah mate get the right ones picture what happens when it spins an you hit the pedal, it will have movemnt that will affect your braking
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby soopachargen » Thu Sep 25, 2008 1:42 pm
rollaholic wrote:the Pvalve on your wagon will probably have more bias towards the back than an FXGT one, if it has the same fittings why not use the AE100 one?
what im doing is converting the rear to discs, so im wondering if using the prop valve from the disc equiped ae92 fxgt would work on my ae100 wagon...?
soopachargen
Postby soopachargen » Thu Sep 25, 2008 1:49 pm
BigDon wrote:It will be an issue, ask Neo. Its not that hard to get the right size disc is it. The superstrut Ae101s have different size holes vs non superstrut 54 vs 55mm but the non superstrut ae101 is the same disc as the non superstrut ae111.
The comparrison i made was sitting the disc backwards over top of the rear disc i already have,
The front discs that i have in my collection are a pair of twin-pot ae111 discs, i'm guessing these are superstrut discs??
The rears i have are a full hub, knuckle disc and caliper off an ae101 gtz with abs, did the abs only come out on the superstrut model???
Will the abs ae101 gtz have a different spigot size to the non abs model?
My front setup (not on the car yet consists of a st185 single pot caliper and the aforementioned ae111 twinpot disc, this all mocks up perfectly on the spare ae92 front hub i have, just when i compare it to the ae101 rear disc it has a minor different in spigot diameter.
soopachargen
Postby KinLoud » Thu Sep 25, 2008 2:25 pm
Hmmm not sure about that.
Drum brakes need less pressure than disk brakes to drum proportional valve will give less pressure to rear brakes.
I vote to use the fxgt one - more pressure with disk conversion to give a better balance to your braking.
My 10c worth anyway.
Ken
Auck
021 408 863
Postby pc » Thu Sep 25, 2008 6:35 pm
I noticed the opposite when I did a reshell AE82 FXGT into AE81. I used the drum brake proportioning valve and found the rears locked up before the front... changed the valve over and haven't had that problem since.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby rollaholic » Thu Sep 25, 2008 6:59 pm
they might need less pressure but the rears will be expected to do more braking on the back of a wagon than on a hatch. either way if you have both you can swap em round till you find one you like, sounds like hatch valve might be the go anyway with above post in mind.
find wagon with disc rear, profit.
Postby Mr Revhead » Thu Sep 25, 2008 7:25 pm
why even convert to rear discs anyway on a road driven wagon?
Postby rollaholic » Thu Sep 25, 2008 8:03 pm
there is that, drums ftw imo. over demonised!
Postby soopachargen » Thu Sep 25, 2008 8:19 pm
reason being wagon is getting a 3sgte
soopachargen
Postby Mr Revhead » Thu Sep 25, 2008 10:49 pm
i can accept that reason :lol:
